Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Picture flutter Hi Dan Thanks for replying so fast. The picture just flutters or jumps, looks like a triple picture till it stops. Than it's fine the rest of the day till shut off and cooled down. Than when restarted it takes a few minutes and will start fluttering again for a few minutes.
  • 4,234 Answers
As I indicated (I think) in another string, this sounds more like bad connections than anything else. Try resoldering the pins on the convergence ICs. Let me know if that does not resolve the problem.
Dan
Posted on May 13, 2008
Tv flutters
Sounds like a high voltage prolbem. I would look at the deflection board part number A1302180A
Apr 14, 2014 | Sony KP-51WS510 51" Rear Projection...
Tv flutters then shuts off
Sounds like a high voltage problem, I would look at the defelction board part number A1302180A
Canon T3 flash flutters and does not take pictures help!
The 'fluttering' is a pre flash used to help the camera focus in low light. The internal flash isn't a powerful flash and is usually only good enough for subjects up to about 2m away in reasonable light also to light a subject that is back lit. Try putting the camera in manual mode (M) 1/60sec on f5.6 flash popped up review it and make adjustments accordingly i.e. open up or shut down the aperture as the flash usually syncs at 1/60
Aug 13, 2017 | Canon EOS 1100D / Rebel T3 Digital Camera
Car fluttering
Your issues could stem from numerous issues. Check out the following website http://www.kiatechinfo.com sign up and you can search for electrical problems mechanical issues etc. Exploded diagrams included.
TAUAHERE78 your issue can could be a timing belt jumping teeth could be a bad fuel pump. could be clogged fuel filter. etc. Is it giving any engine codes etc.
Guest: Your issue could be timing belt as well. or bad coil check the above website and do some troubleshooting or bring it in to dealer
Thanks for using FIXYA
Dec 20, 2008 | 2004 Kia Optima
No Juice speed tach and lights flutter
I just had this happen to mine the other day. In my case I had mine jumped but after a drive it around to make sure the battery was charged I had let it sit for 12 hours. I got in that night and it would not turn over. That that moment I knew the battery was not holding a charge. When I checked the battery I saw that I had the original factor battery. So after I changed out the battery I did not have any more problems.
Hope this helps
Issken
Nov 26, 2008 | 2005 Ford Escape
Fluttering noise in engine while accelerating at a fast rate
I believe you may be referring to 'pinging', Try a tank of premium gas and see if it stops. Check your timing, and when was it last tuned? Let me know what u find. countrycurt0
Oct 02, 2008 | 2002 Ford Explorer
Fluttering
sounds like bad controller.
Jul 09, 2008 | 1991 Honda Accord
Jumping or fluttering picture when playing
Hi...
Jumping picture scene or sounds.. are made by defective Pick up Lens.. or Flex ribbon Wire!!! Replace a new one!!! How old your unit?
Thanks!!!
Jun 19, 2008 | Insignia Televison & Video
Horizontal won't stop fluttering
call tech and suggest to repair the horizontal drive ..
Nov 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Fluttering
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 10, 2007 | Mitsubishi VS-60607 TV
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
