My headphones jack is broken i've tried to plug my headphones into the jack but it is not working at all please help!
    Guru:
  • 689 Answers
This really is a common fault with most pc's ,a few years ago it was this and theold ps2 mouse sockets that would fail.
If you can take it apart very carefully and gently find the fault broken connection wires/solderd points .You could repair it yourself.
almost as common as this problem is the jack plug on your headphones they fail more times than mr singh and the a-level examiners daughter,to coin a corrupt phrase!
Posted on Sep 06, 2010
No sound tcl 40F S3800
when headphones are plugged in a conection is broken to stop sound coming from speakers try plugging in and out jack plug for headphones a few times
Jan 02, 2017 | Televison & Video
My dell latitude d510 internal spk is ready but output headfone jek not working
these are fairly passive in that if a headphone or earpiece is plugged in, they switch the output from the internal speaker to the external speaker. So, it's usually one of a few problems.
  • The jack is mucked up, and needs replaced.
  • The headphone plug wires have a broken connection
  • The headphone needs power to amplify, and that's not working.
If trying another headphone or earpiece you know is working doesn't work, it's the jack itself. They can only handle so many uses before they either fail closed, or open or completely. Depending on which one, either:
  • neither speakers nor headphones work.
  • only speakers work
  • only headphones work
Replacement necessitates opening the case and replacing the jack. For that, there's no help.
Sep 02, 2015 | Dell Latitude D510 Notebook
When I plugin my headphones The sound dosn't go to the headphones.
First, try plugging in different headphones. If those work, then your headphones are broken and you need to replace them.
If those don't work, then please check to make sure you're not plugging them into the microphone jack - you'll see two identical plugs, usually the headphone one is marked with a pair of headphones.
If you're plugging known working headphones into the correct port, then your computer must logically be the broken thing.
Dec 20, 2013 | Motorola Mobility S9 Headphones
Headphone jack doesn't work
It could be there is dust in your jack. Cut down a Q-Tip and stick it in. If that doesn't fix it, it could possible be the jack has gone out. There are USB sound cards that would provide a jack.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812705175&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Other+Adapters+%26+Gender+Changers-_-N82E16812705175&gclid=COqQ9aX977QCFXCmPAodogYAUw
Jan 17, 2013 | Computers & Internet
Headphones not working
try geting a new jack if not bye a now wone
Jul 25, 2012 | Harman Kardon AVR 7000
Headphone not working
Try the headphones on another computer. Maybe the headphones are broken. If not, make sure you have the volume turned up and not on mute. And make sure you plug the headphone into the Headphone Jack not the Microphone Jack.
May 08, 2012 | eMachines Computers & Internet
My garmin 660 won't transmit audio through speakers or fm transmit. I go to audio output and it says that "Audio output can not be changed when using headphones" I can use it with headphones...
You have a problem with the headphone jack. Please see this link and read the section about BROKEN HEADPHONE JACK
http://www.sharc.net/gps_audio_repair.htm
Because there is a broken connection, your Nuvi thinks there are headphones connected at all times, so you wont be allowed to change the sound options. I've repaired this problem many times. Don't try it yourself, you risk damaging your Nuvi beyond repair.
- Jim
SHARCNET-USA
Jul 19, 2011 | Garmin Nuvi 660 GPS Receiver
Sound Issues w/ PSP-1000
Your headphone jack is probably damaged and needs replacement. Here is one I found on the net: Repair your broken "Hands Free" socket, soldering required. This item is also available pre-mounted to the board, ready to plug in. Free shipping.
http://powergamingparts.com/psp-socket-and-housing--replacement.html
Nov 22, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
I can only hear out of one headphone i ve bought new headphones it just want work
Hate to tell you this, but most likely the headphone jack on your player is broken. It happens alot. If it's under warranty return it to the store. I don't believe the jack is user replaceable on this player. Try inserting the headphone jack only partway and see if you get both sides. Your cheapest solution if it's out of warranty may be to just insert the jack to the point at which you get both sides to work. It's a crappy solution, but it's probably your only hope. It's not a software problem or anything that can be fixed without tearing the player apart. Sorry for the bad news....
Aug 01, 2007 | SanDisk Sansa c140 MP3 Player
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
