Question about Ovens
Do I need to put water in the bottom to cook a tenderloin?
  • 50 Answers
~In the bottom of your oven???? No way!!!!
In the pan? Consult your cook book.
Posted on Sep 06, 2010
How to defrost a roast lamb in a vario stream oven
Have a read of this. I am a chef and would advise the traditional way.
Cooking a Frozen Roast Without Thawing - Cooking - eGullet Forums
https://forums.egullet.org/topic/112634-cooking-a-frozen-roast-without-thawing/
Feb 5, 2008 - 25 posts - ‎15 authors
So now there's a 10 or 11 lb. beef shoulder in the oven. ..... roasts with additional water added as required were put into a large steam kettle to ... This works with any meat Pork, Lamb, Beef or even Frozen Turkeys especially at ...
defrost roast lamb in vario stream oven Google Search
Apr 30, 2017 | Ovens
1.8 lb pork tenderloin. What temp and how long do I cook this in my oven?
http://www.porkbeinspired.com/wp-content/uploads/2014/06/2924.pdf
Jan 24, 2016 | Ovens
Why is mu beko cooker building up steam in the over and making food all soggy comet have told me not to cook food with any water in but thats impossible
You do not normally cook with water inside the oven, ovens are for dry cooking only, rings are for boiling water and used for cooking this style
Jul 12, 2011 | Ovens
The cooking is not even when cooking small items
Often times this isn't something you want to attempt to rectify yourself. If you can find a way to deal with or adjust to this issue it will save you the cost of a repair visit. If the uneven bake is so severe that you cannot cook in the oven and you still wish to attempt repair by yourself you first need to identify which racks aren't cooking correctly and in which pattern is it uneven.
For example is the rack uneven in overall color from top to bottom, meaning are items on the top cooking to quickly where as the items on the bottom are uncooked? Or is the uneveness lateral where the center of a single tray is over/under cooking or the edges of a tray are over/under cooking.
Once you've identified your issues you need to locate your airflow louvers. They are usually located in the back right corner of this oven, it is where the hot air comes out of the heat exchanger chamber. You will notice there are gaps and there are fins. Adjusting the fins changes the way the air flows from side to side across your product, adjusting the gap changes how much hot air reaches the product.
Lets approach side to side uneveness first. To compensate for the center of a tray UNDER cooking take the metal fin lined up with that tray on the RIGHT side and slightly bend it to the left, directing air towards the center of the tray. If the center is over cooking bend it to the right, directing air away from the center of the tray.
For top to bottom uneveness you will need to loose the screws/bolts holding the fins in place and gently increase or decrease the gaps. Be careful here because if you loosen the screws too much the louver can slide out of place and make to large of a gap, potentially making things much worse. A good trick is to take a permanent marker and make a mark to where the louver was before you adjust it incase you need to put it back.
If a single tray is too light in relation to the other trays increase the gap, if it is too dark, decrease the gap. Do this for each tray that is coming out uneven. Make small adjustments and then do a bake to check the results, there may be a lot of trial and error involved.
If this seems overwhelming you're probably better off not attempting this because you can make things worse to the point where NOTHING comes out correctly, if that's the case call your local authorized service provider. Good luck!
Jan 03, 2011 | Baxter BXA2G Stainless Steel Gas Single...
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
How do I remove aluminum foil from the bottom of my oven? I have a brand new Kenmore wall oven that I have only used once. I had put a piece of foil on the bottom in case there were any drips. it baked on...
To all those who think this problem description couldn't be true, you're wrong. You're right that the aluminum did not get hot enough to melt though.....What happens is that the non-stick teflon coating they put on the aluminum get's too hot and bonds with the oven bottom.... like a crazy epoxy!
Furthermore, this isn't a problem in older, conventional-type ovens... this is moreso a problem with ovens that have a hidden bottom element.... The bottom element is actually directly below the oven bottom, and lining the oven bottom with foil is basically like putting it directly on the element. And that part gets extremely HOT!!!
Thankfully I've got the solution to this! But it takes some extreme patience, a lot of respect for what you're working with and some good ventilation.
I went back to my high school chemistry class to get the answer. It's Lye, aka Caustic Soda aka, Sodium Hydroxide.
I used Drano Kitchen Crystals off the shelf of the grocery store..it's about 70% lye with some added salts to aid the chemical reaction.
You'll need some plasticene, the drano, water, GLOVES!!, a lot of paper towels and wood skewers and GOOD VENTILATION.
Start the ventilation and open a window or door.
Put on your gloves.
Use the plasticene to create a dam about .25"-.5" high around the area in the oven you're looking to remove the aluminum from... the area's you're working in should be about 2.5" in diameter.
Pour in some of the drano into the dam and add enough water to touch all the sides of the dam......if the chemical reaction hasn't started (should be almost instant) keep adding the drano bit by bit until it does... the dam contents will start to boil and ammonia fumes and a little hydrogen gas will form....... hence the need for some good ventilation!!
Once the reaction is done, poke around with the wood skewer to see if the oven bottom is clear... if you're satisfied with the results, add some some vinegar in to help neutralize the solution a bit.... then use the wood skewer to remove the plasticene dam to a dish to be rinsed off ASAP.
Use paper towels to wipe up the mess on the bottom of the oven.... See your results! the area of the oven botton you treated should be free of aluminum and just be discoloured instead..... not from the drano, but from where the teflon bonded.
Repeat the process until the oven bottom is clean.
To get a 'feel' for the chemical reaction and what to expect, experiment first!... take a square of aluminum foil, go to the backyard with the foil shaped in a littlebowl and place it on a dish or pan, add some drano crystals to it then add a little water... step back from the dish and try not to breath the fumes!.. the dish will be hot!!
It took me about 6 hr to clean the bottom of my oven when this happened to me.
Hopefully this helps some other poor unfortunate souls who finds themselves in this situation!
Oct 15, 2009 | Kenmore Ovens
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Concealed oven
consealed bake means that the bake element on the bottom had a metal plate above it to make it easier to clean and to allow you to use the lower racks without burning the bottom of your food. To use, you want to make sure that the oven temperature that you set has been reached before putting in your food to be cooked. You also should put the racks one notch lower than you normally would. If you do this, you should have no problems with your food cooking unevenly.
Jun 28, 2007 | Amana AOCS3040SS Electric Single Oven
Ovens Logo
94 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
