where does the drain hose connect? Once I find that out, I should know
the hose diameter so I can go to ACE Hardware or Home Depot and buy
the length of hose I will need.
-   Do you have to break the opening guard?
I bought the hose at Sears but I am not
sure that the large diameter of the hose conector will
fit through the opening. Do I need an addopter?
Unfortunately my wife tosed out the box and with it
the instructions and posibly the conection part.
E-mail k.verebey@att.net-   verebes
ehumidifier is set on high and runs continuously but no water collects. It used to collect a...
(More)
ehumidifier is set on high and runs continuously but no water collects. It used to collect a container a week at least
The unit was working just fine but now it won't run at all. The light isn't on, the fan doesn't run....
(More)
The unit was working just fine but now it won't run at all. The light isn't on, the fan doesn't run. I unplugged it and let it sit overnight. Still nothing. The receptacle has power so it's defintely the unit.
i have 3 dehumiifier- two of them works for about a minute then stops .i then turn off the unit and...
(More)
i have 3 dehumiifier- two of them works for about a minute then stops .i then turn off the unit and on again and it works for about a minute then stpos again and so on.one of the three units works fine-this same unit is older than the other two.Ironically the other two were hardly called to do any work at all before i noticed they were not working
My Kenmore 54351 dehumidifier (35 pint) runs for a bit, then stops. I see this problem appears to be...
(More)
My Kenmore 54351 dehumidifier (35 pint) runs for a bit, then stops. I see this problem appears to be common, according to the posts here. I have cleaned the filter (didn't know it had one) and it ran a bit and then stopped again.
Is there anything else I can try? This worked beautifully up until this spring.
My Kenmore 54351 will start and run about one minute and shut off. If I turn the humidity control...
(More)
My Kenmore 54351 will start and run about one minute and shut off. If I turn the humidity control all the way back to min and turn toward max again it will restart and do the same thing all over again. The red light does not come on at any time.
