Question about Riccar 8850 Vacuum
I have a 8955 riccar vacuum. my roller brush is not working very well on the carpet . I took it apart and now I am not sure on how it goes back together. Could you send me a picture of how the rooler part of the roller brush goes back together. Thank You. Paul
reddevil6
  • 1673 Answers
SOURCE: how to replace Riccar Roller Brush Bristles.
On the belt end, there is a clip #59 to remove then you can take the brush roll apart, replace the brush strips and put it back together.
Posted on Jan 11, 2009
  • 25 Answers
SOURCE: riccar 8955 sweeper won't run...where is thermal protection switc
thermal reset is located on the back of the machine at the bottom
Posted on Mar 03, 2009
VacuumRepair
  • 438 Answers
SOURCE: Riccar 8700 Brush Roll
Greetings,
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum cleaner is unpluged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unsrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift staight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, posistion the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Step 12: There is a flap that can be opened after the metal bottom plate has been removed, that will give you more access to the motor shaft. Make sure that this flap is closed;
Step 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as low as if the bottom plate is correctly installed. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. The lip is a little tricky, but after doing it just once, you'll have no problems in the future changing your belt.
Here's a picture of the bottom plate installed INCORRECTLY with the bottom plate over top of the lip;
Here's a picture of the CORRECT way to install the bottom plate:
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the Thumbs Up Icons in the lower right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Thank you very much,
Chris Jones
Posted on Mar 21, 2010
VacuumRepair
  • 438 Answers
SOURCE: roller does not turn
When a Dyson DC07 makes this horrible grinding noise, it can only mean one of three things.
The Dyson DC07 uprights use a clutch mechanism to control the brush spinning when you change the floor / carpet switch. When you hear this grinding noise, it's actually the clutch slipping because it can not spin the roller brush. Most other uprights use a belt to spin the roller brush, and if something is stuck in the roller brush it will cause the belt to break. Dyson's however will make that awful grinding noise rather then breaking the belt, and will only make that noise if the roller brush can not spin.
When you hear this noise on a Dyson, it can only be 1 of 3 things. Either your clutch mechanism itself has gone bad, or the roller brush itself was not properly put back into the vacuum, or the brush itself has gone bad.
I'll be happy to walk you through step by step on how to diagnosis this problem and find out which one of these two parts is bad on your vacuum2_bing.gif.
Step 1. Make sure the vacuum is unplugged. Then turn the vacuum upside down so that the brushes are facing up. It's easiest if you put the head of the vacuum on top of a bench, or counter top. This is how the vacuum should look:
Step 2. You see on the bottom of the vacuum 3 plastic screws that are usually the same color as the vacuum cleaner2_bing.gif. If you're vacuum is purple, the screws will also be purple. Use a flat head screwdriver, and turn each of the 3 screws a half of a turn, counter clockwise to loosen then. After each screw has been turned (you don't need to remove the completely, just a half of a turn is all), simply pull upwards on the bottom plate to remove it.
Step 3. You should now be able to see the roller brush exposed. You'll now need to remove the roller brush. This will take some patience, and some work in order to get this brush out of the vacuum. There is a special tool that has been designed to help you get the brush out easier. I would try getting the brush out first before buying this special tool. The easiest way is to use a flat head screw driver and pry the belt up while pulling up and out on the brush. With some patience and some maneuvering, you'll be able to get the brush out of the vacuum. Here's where you should put the flat head screw driver on the brush:
Step 4. Once you get the belt out of the vacuum cleaner, it's time to test it. Use your finger tips to hold just the end caps on the very end of the roller brush. While holding just the end caps, use your thumbs to try and spin the roller brush. Does the brush spin freely? It should rotate completely several times on each spin. If the brush doesn't spin, or you feel some kind of resistance to the brush spinning, then this indicates that your roller brush has gone bad. Here's a picture of how to test the brush:
If the roller brush went bad, then you'll need to purchase a new one. Here's a direct link to the roller brush your machine uses on our website GoVacuum:
http://www.govacuum.com/dysondc07.html
If the brush however was able to spin freely, and it spun multiple times, this indicates that most likely the brush was not put back in properly, or it could be a little more serious of problem in the clutch itself has gone bad. The clutch replacement repair is a much longer, more challenging repair to do. There is a very helpful video on how to replace the clutch below so that you may follow step by step instructions on how to change it. It was really helpful for me the first time I did this repair.
I think more likely however it's probably that the brush was not put back in properly, and this caused the brushes not to be able to spin, which would cause the clutch to make that horrible noise. Make sure that the roller brush is pictured like the brush above, you may also want to make sure that the bottom plate is put on correctly, this could also prevent the brush from spinning:
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
If you need to replace the clutch, here's a direct link to the clutch your Dyson DC07 uses on our website:
http://www.govacuum.com/dydcclasfore.html
Here's the video on how to replace the clutch:
When you hear that grinding noise, it can only be one of these three problems. This clutch mechanism was so problematic that Dyson removed it on the second series of the DC07 models. I hope that this repair was helpful in diagnosing your problem. If you have any questions about the diagnosing, or the clutch change, please feel free to use the Clarification Request form here on the Fixya repair page. If this was helpful you, please be sure to rate my repair as helpful by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Posted on Apr 07, 2010
  • 53 Answers
SOURCE: dyson dc 17 vacuum. brush not moving
The cog belt is probably not aligned with the motor gear. Watch this video and follow its instructions closely.
Posted on May 31, 2010
Why does the riccar vacuum reset button not depress?
In my experience the Riccar requires reset when it has ingested something that jams the roller such as the fringe of an Oriental carpet. Be sure to clear any such obstruction, then I use a ball point pen to press the button. It does not move very far to accomplish a reset.
Jun 18, 2014 | Riccar 8955 Upright Vacuum
Riccar 8995 no suction
If it's been over a year since you've replaced the belt that is the first place to start. Stretch belts lose elasticity and will still turn the brush roll but when the brush roll is lowered to the carpet it may not turn fast enough to pick up properly. If you have good suction at the end of the hose check to make sure there is not an obstruction in the tube where the hose goes into the bottom of the vacuum to the brush roll. Make sure your filters are replaced at least once per year and the bag is not full or has a lot of fine powder dust in it which can clog the bag.
Jun 13, 2014 | Riccar 8955 Upright Vacuum
How do I change a belt in a Riccar vacuum
Remove the screws holding the bottom plate on. Remove bottom plate. If it's an 8955 or model with clutch to shut off the brush roll remove the rod that goes from the lever to the clutch. Look closely how the rod and brush roll are positioned in the vacuum so you can reinstall it the same way. Remove the brush roll and install the new belt and then put back together as it was.
Apr 30, 2014 | Riccar 8955 Upright Vacuum
Not picking up. No suction
Make sure good suction at the end of hose and no clogs in tube hose goes into at bottom of vacuum. If good make sure belt is new and brush roll spins fast when lowered onto carpet. It may need clutch adjusted or rubber pad replaced.
Oct 06, 2013 | Riccar 8955 Upright Vacuum
Brush on riccar vacuum how to change clutch on brush
The clutch is part of. The rush roll. Remove the brush roll and take the clip off the end to take the brush roll apart.
Feb 16, 2013 | Riccar 8955 Upright Vacuum
Won't pick up dirt and hard to push
This sounds like it is most likely a belt issue with your Riccar. In order to verify this, turn the vacuum on and turn it over on it's side after making sure that the carpet / floor switch on the top of the roller brush housing is turned to Carpets.
When you turn the vacuum on after changing the switch to carpet mode, does the roller brush spin? The belt controls the the roller brush and makes it spin. When the belt is broken or stretched out, and the brush is not spinning, or stops as soon once it hit carpeting, the brush roller will no longer help pull the vacuum forward. This would explain why the vacuum is very hard to push.
In order to help you the best, I went ahead and took some pictures for you on how to change the belt. The only really tricky part is the clutch actuator arm. If you don't already have a new belt, here's a link for you to a 2 pack of belts for your 8955 on our website:
Riccar 4000 / 8000 Series Upright Belts (2pk)
The model that I took pictures of is actually a model 8650, but this is identical in every way to your 8955 in terms of changing the belt.
Step 1: Make sure the vacuum2_bing.gif cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Step 3: Remove the belt guard that sits to the left of the roller brush, this is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 5: Once you have removed the actuator arm from the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take a new belt and wrap it around the metal pin in the back of the vacuums agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), put the other end of the belt through your roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, as well as continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there are two little teeth that protrude out of the end cap. Here's a picture of how it looks:
Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove inside of the roller brush housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Make sure that the rug / floor switch set to the carpet setting again, and then turn the vacuum upside down again so the brush and belt are exposed again.
tep 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as close as if the bottom plate is correctly installed. It will take away the vacuums cleaning cleaning ability dramatically. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. This is the way it will look if the bottom plate is installed the WRONG way.
Here's a picture of the RIGHT way to install the bottom plate:
The Riccar 8955 is great vacuum, and cleans better then most other upright s when it has a new belt on. I hope that this repair solution is helpful to you in fixing your vacuum. If you did, please be sure to click the Thumbs Up Icons in the top right hand corner of the solution. Feel free to request a clarification on the repair if you have any questions. I'm always happy to answer any questions. I hope will consider GoVacuum.com storefront for any Riccar supplies that you may need. We carry all Riccar Vacuum Bags, Filters, Belts, and Parts.
Chris J.
GoVacuum
Apr 03, 2010 | Riccar 8955 Upright Vacuum
How to replace the belt in the 8850 model
Greetings from GoVacuum,
Step 1: Make sure the vacuum cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the 4 Thumbs Up Icons in the top right hand corner of the solution. Feel free to send me an email, or request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions. Be sure to check out our website for any Riccar parts that you may need, including; Riccar Vacuum Bags, Filters, Belts, and Parts.
Chris Jones
GoVacuum.com
Mar 19, 2010 | Riccar 8955 Upright Vacuum
How to replace belt on Riccar
Chris Jones
Feb 22, 2010 | Riccar 8955 Upright Vacuum
Can't get the belt to engage for carpet cleaningwith my riccar
Step 1: Make sure the vacuum2_bing.gif cleaner is unpluged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners2_bing.gif agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continously having to replace belts2_bing.gif. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Thank you
Chris Jones
GoVacuum
Jan 17, 2010 | Riccar 8850 Vacuum
Greetings,
Chris Jones
Oct 11, 2008 | Riccar 8955 Upright Vacuum
Vacuums Logo
160 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
