Question about Baumatic BW18 Wine Cooler
Baumatic BW18 wine cooler; at the back: red&green led, soft humming, clean filter. At the front: cooling capacity: zero after 2 years excellent functioning
  • 7 more comments
  • janwilmsoost Sep 13, 2010
    I bought a wine cooler with a peltier element for reduced vibration, your "expert" come with a replacing it by a coke vending machine ?!
    maybe you have someone from the elctronics department?? what are the two leds at the back indicationg, some malfunction ??
  • janwilmsoost Sep 17, 2010
    It is the Baumatic BW18 - no further model details - running on 220V
    Everything funtions, the fan hums and the humming changes if I turn the hi/lo button on the upper-right frontside.
    At the back (after removing the panel) there is a tiny piece of electronics with a green and red led alight. A heavily glued (with epoxy I guess) glass fuse that looks OK, a huge peltier that may or may not be broken. Air filters are clean.
    At the inside the light is on and the temperature is ambient.
    The Baumatic BW18 wine cooler is not cooling - that is the problem
    come on, this machine has no condensor but works with a peltier
    previous expert babbled about a condensor after I told him the Baumatic BW18 has a peltier element
  • janwilmsoost Sep 18, 2010
    The Baumatic BW18 has no compressor, but a peltier-element for cooling. The humming is the fan. Your advise is not relevant
    Yet another expert that does not understand that the BW18 has a peltier element and therefore not a condensor, nor freon etc etc.
    One more strike to go
  • janwilmsoost Sep 19, 2010
    I have reported it in full detail three times - what info did you already get? do you know anything specificabout the Baumatic BW18, or on peltier elements? This is not a fridge, it has no condensor, no freon
  • Anonymous Mar 13, 2014
    e2 flashes up on my baumatic wine cooler
    who in wellington or hutt valley repairs baumatic wine cooler
  • 712 Answers
Sorry, will you please describe your problem clearly?
Posted on Sep 18, 2010
  • 2,427 Answers
The soft humming your hearing could possibly be the compressor stalling.. this can come from a lack or freon. Now this is the first thing you should check as its one of the most common issues in all refrigerant systems.. to do this there is a check port that you connect a guage too and it will give the freon pressure. More than likely you will find it very low and needs re gassing.. before having it regassed I'd suggest that you have it checked for leaks as well ,, (it ran out of freon rather quickly no ??) have a technician come in and check these as he will have all the right tools and stuff needed for for the checking of gas pressure, the dye to check for leaks as well as the freon to regas it.. and if needed the solder to fix any leaks..
Posted on Sep 17, 2010
  • Rishi Roshan Ali Sep 17, 2010
    Oh,, Btw could alo be the compressor it self is shot,, but lets hope its just the gas.. (cheaper to fix) if its the compressor you will have to
    • change compressor
    • check for leaks
    • regas..
    Thats why it isnt cooling as well.
  • Baumatic Master
  • 1,711 Answers
Could you please check and reconfirm the model of your cooler and try to give us more clear what is your problem and how it apear
Posted on Sep 13, 2010
  • espressonist
    espressonist Sep 17, 2010
    The compressor overheating safety switches it off for protection from overheating and result in complete damage of the compressor.
    One and most possible reason is the condenser is full of dust.
    Turn on the back of cooler and either sweep away or vacuum dust that is readily accessible.
    This easy cleaning should be done at least once a year for most efficient operation.
    If you stiil have no cool then when you listen closely you hear a click with a buzz, another little click and then nothing for a few minutes. Then the same thing starts all over again. You fear the worst and you are probably correct. The compressor has decided that it will not start anymore.
    When this happens, sometimes it is the fault of the capacitor or the start relay. There is about as good a chance that changing these components will work as it is that it will not work. If you can do the changing your self then you should get the parts and do the work. You have half a chance that it will work. If you will need to pay someone else to do the work then you need to look hard at what it will cost you and what the unit is worth, then decide to take a chance or not.
    Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
    As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
    There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly
  • 22,265 Answers
I have one that i havent even got 2 yrs out of ,and if its the same as mine then its lost its gas and they are not top upable like a car ,i asked at the local shop where they repair these things and beer coolers and coke machines ect and as its made in china and so cheap i was told to just buy a new one ,well it did only cost 79 euros anyway the guy sold me an old pepsi drink cooler for 50 euros and its although its 10 yrs old or more it works a treat and their is a top up valve that looks like car valve ,so i assume its R!12 gas and not R134 but who cares if i need to top it then i have car air con machine and the R12 adaptors so it will work on R134 although not as cool but for a few cartons of orange juice and water who cares
Posted on Sep 06, 2010
Upper & lower level does not cool. Temperature stays at 78 for lower level & 75 for upper. In attempting to set cooler temperature at 55 for top and 45 for lower it immediately reverts back to 78...
take shelves off. temp display unit in middle of shelf is where circuit board is for testing. pull middle unit forward and unscrew back panel. check lines for leak. color should look like a teal green. thats where your leak will be. Need tech. for the rest.......good luck!!!!
Jun 02, 2011 | Danby DWC283BLS Wine Cooler
Can you cool bottle beer as well as wine
yes...beer will be fine in the cooler
Jan 03, 2010 | Baumatic BW18 Wine Cooler
Vinotemp 2 zone wine cooler flashes "Lo" on numeric display for lower compartment - will not hold temperature requested. Temp in upper compartment will not go below 67 even though it is set for 51. Room...
Not sure, but did you clean the filter in the back? Ours has that, and the temp starts creeping up every few weeks until I clean it. But we've never been able to get it below 58 or so, and in the last year, not below 60. I think that's just the nature of this type of cooling. Our house is also at 80. But, can keep it at 60 with the above cleaning.
Jul 22, 2009 | VinoTemp (VT60GNV) Wine Cooler
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
Magic Chef MCWC8DSCT Wine Cooler
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
Nov 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Koolspace 600 Problem
You'll need to replace the fan. The original fan bearings wear our after a couple of years. It's pretty simple to drill out the rivets and replace the fan. I suggest you replace all four with ball-bearing fan units.
Sep 19, 2008 | Vintage Keeper Koolspace Wine Cellar
Code E2 showing in temparature display
I contacted the technical team at www.baumatic.co.uk and here is the reply I got.
-----Original Message-----
From: Samantha.Codd@baumatic.co.uk [mailto:Samantha.Codd@baumatic.co.uk] On Behalf Of Technical@baumatic.co.uk
Sent: 25 January 2008 13:02
To: Taline Bedrossian
Subject: Re: BWE40 wine cooler
Good Morning.
Thank you for your e-mail.
This error code means that your appliance has experienced a defrost sensor
fault. Please contact our service team on 01189 336 911 to arrange a
suitable time for an Engineer to visit you.
Kind Regards
Quality and Technical Department
Baumatic Ltd
www.baumatic.co.uk
Jan 19, 2008 | Baumatic BWE40 Wine Cooler
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Nov 25, 2007 | Haier BC112G Wine Cooler
Baumatic BW18 Wine Cooler Logo
318 people viewed this question
Top Baumatic Refrigerators Experts
Sal De GO PATS
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
