My Rheem AC runs and cools fine during the initial cooling period. Shuts off when the set temperature is reached. But when the 2 degree drop in the house temperature is reached the contactor closes and releases immediately. This repeats about every 4 seconds. I have 220 volts at the contactor nd have replaced the contactor.
    President:
  • 1,515 Answers
Hi what the problem is, the contactor coil is 24 volts and is controlled by the thermostat, If it pulls in and out, the 220 volt contacts, you more then likely have contacts that are worn in your stat and not the contactor. This is the only other part that controls the coil on the contactor. It takes very little wear on the contacts in the stat to bring on the contactor or cause it to short cycle on and off like it has been. Check out all of your wire, control wiring from the thermostat to the unit, and I would replace this stat and solve your problem. Please keep me posted on this and I will check back in with you. The stat is your problem though. Please don't forget to rate me as I know you will be kind, and let me know the out come or if you need my help on this.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 06, 2010
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
My frigidaire a/c is set 73fhrenheit after running for a time the temp. on the unite drops to 60 degrees by it self what is the problem ?
AC units, no matter if they are big/small, window or big central units. They will only cool the air in the room, or home, to about 15 degrees cooler than the outside air temperature. If you live in Georgia and it is 100?F+ outside, you will be lucky if the unit will reach 80?F even running all day.
Jul 22, 2012 | Frigidaire FRA186MT2 Window Air...
Rheem split system condenser high pressure limit/safety needs resetting frequently before it reaches the set temp of 76 degrees faren. what's wrong and what do i need to check?
Is the outdoor fan running? The fan cools the coils and compressor, therefore keeping the high pressure low enough to run. Either the fan is not working or its not spinning fast enough. Check the capacitor, or just replace it.
Apr 18, 2017 | Heating & Cooling
My chevy venture 2003 only over heats when it is still with the engine on but it does not over heat when i drive it, what could it be?
Odds are your electric cooling fan[s] isn't coming on. This fan should only run when the a/c is on or when the engine temperature has reached about 218 degrees. Once the a/c is off or the engine temp drops to about 210 degrees it shuts back off again. It rarely comes on at speeds over about 35 mph because at that speed enough air is forced through the radiator to keep the engine at about 198 degrees. I would start by looking for a blown 30 amp fuse under the hood. There may be two of them marked "Cooling fan 1" and "Cooling fan 2" or something similar. If the fuses are good you could have a faulty cooling fan motor that just isn't running. Hope this helps a bit!
Jul 08, 2010 | Chevrolet Venture Cars & Trucks
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
Thermostat takes too long to cool down 1 degree
Thermostats don't cool or heat. They are just the control device that tells the furnance or AC to operate and register the present temperature and tell the furnance or A/C to shut off, once the desired temperature has been reached.
Most programmable thermostats will take at least 1-2 weeks to "learn" how long to run the furnance or A/C in order to reach the desired temperatures you've programmed into it, for the time you want it be that temperature. Variables such as extremely hot days and higher humidity will also affect your cooling system.
Give it a little time to self-learn and it should adjust itself after a week or two of operation. You might want to take some time to review and familiarize yourself with the owners manual to see what Hunter advises for setting up and using the thermostat.
You may need to have your A/C checked to see if you're running low on freon, or need to have the coils cleaned, need to change the air filter, etc.
Hope this helps and best regards!
Aug 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
