Question about Zareba Electric Fence 600 - 7,000 Volt Eight-Light Voltage Tester #RSVT8
I have solar electric fence charger that is not working. Solar panel output is okay (10 V), and fence charger output works when hooked up to a new battery or working directly from the solar panel with the battery disconnected. Voltage into 6V battery (trickle charge) seems low at 2.5 V. Do I just need to replace my battery or is the trickle charger shot?
My solar panel is not working in my birdbath fountain. When I did a troubleshoot it said to test the unit with the fence unhooked. What is the fence?
Check the pump to see if there is a blockage stopping the impeller from moving. If you have a volt meter, measure the output of the solar cell in bright daylight to see if it is producing the correct voltage.
Jun 19, 2016 | Solar Electrical Supplies
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
Solar pac 12 Battery has charge...panel is delivering charge ...No needle action when turned on and no current at bottom lugs...Thank you for your help.
With the fence connected or not?. with; then disconnect and turn it on again . if it works fence problem if not unit problem. with-out; unit problem . most likely PCB
Jun 26, 2011 | Parmak Solar Fence Charger
Installed the new solar charger in July. ZThe hot wires and ground wires are properly connected, snd the fence is properly grounded. It worked great until approximately two week s ago (end of Sept). The...
I have see this happen before and its usually do to most moisture/rain getting in. ie use multi meter to varify solar charger putting out current/voltage. Odds are its not anymore. Rechargable batteries are notorius for not lasting but not in 2 months.
Oct 07, 2010 | Parmak Solar Fence Charger
HOT LEAD FROM SOLAR PANEL HAS A ELECTRICAL COMPONENT WHICH IS BROKE. WHAT IS IT? (6-V)
Either a voltage limiter (because a solar panel can put out upto 21 volts.... BUT more likely a diode - which prevents the storage batteries from discharging through the solar panels (power goes only INTO the batteries when the diode is working.
Radio Shack will be able to match it if you remove it and take it to them.
Jan 21, 2010 | Parmak Solar Fence Charger
No shock from charger
did you make sure the fence isn't grounded or an insulator hasn't melted
Apr 12, 2009 | Parmak Solar Fence Charger
Zareba Electric Fence 600 - 7,000 Volt Eight-Light Voltage Tester #RSVT8 Logo
999 people viewed this question
Top Zareba Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Zareba Measuring Tool and Sensor Expert? Answer questions, earn points and help others
