Question about Dell Dimension 5100 (D51L1) PC Desktop
CD/rw won't play or record how do I fix it? Dell Dim 5100
  • Dell Master
  • 5,479 Answers
First check the device manager and see if there is a yellow triangle with an exclamation point or red x for the CD drive. (Control Panel > Hardware > Device Manager, slight variation with OS version.) Try to update the driver (see Dell.com for downloads). http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIMENSION%205100&os=WW1&osl=en&catid=&impid
Next check if the ribbon cable came loose from the motherboard or the CD drive (open the case). Try cleaning the unit with a disc cleaner (if the unit will spin the disc).
Optical drives are fairly cheap (~$20 for OEM internal DVD R/W drives) so you are better off just replacing the drive (assuming you do not want to upgrade to an internal Blu-ray drive). The current drive is IDE so you may want to stick with that (the motherboard only has 2 SATA connectors). To remove the old drive, unplug the computer, disconnect all cables, remove the side and front panel. Disconnect the power and data cables. Hold down the sliding plate lever (push toward the bottom of the computer) and slide the drive forward. Put the screws in the new drive and slide it into the space. Plug in the data and power cables, close up the computer and turn it on. The cables should only fit one way.
I hope this helps.
Posted on Sep 06, 2010
HL-DT-ST-CD-RW GCE 8483B WON'T BURN cd
What software are you using to burn with? Have you tried other CD's? What are you trying to burn? Is the file/files copyright protected? Will the DCD/CD rom play media? Have you upgraded your OS?
Dec 12, 2012 | Dell Dimension 2400 PC Desktop
When I try to listen to the cd's, it won't play them. It tries to acknowledge them but the player won't play them
CD players commonly will not recognize some types of CD, eg MP3 recordings, or maybe CD-RW recordings.
However if this is happening with CDs that would previously play OK, then it could be
- scratched or dirty CD surface
- contaminated laser lens in the player
- laser lens has become misaligned
The last 2 need a service technician, but it may be cheaper to buy a new player.
Nov 19, 2011 | Audio Players & Recorders
What is the difference between a DVD+RW and a DVD-RW.
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Aug 22, 2011 | Acer Computers & Internet
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Will not play a Memorex cd-rw
try again! burn an audio cd, but burn it at max 12x speed!!
Oct 28, 2009 | Tascam CD-RW4U CD Recorder
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
What type blank CD is compatible with 48X CD-RW/DVD combo drive
the cd u need to buy is cdr
and is your cd rom a cd rewriter?
good luck
hope i was a help
Mar 22, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Dvd-rw drive not working
Hi Elaine, Usually DVD recording issue can be related to the configuration or Hardware itself. please check if standard CD/DVD recording option is active you can see it by right click on CD/DVD drive and properties. Please check the box highlighted below
If it doesn't work you can contact to DELL hotline or alternately you can post the outcome on here
Good Luck
Feb 07, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
CD-ROM
CD ROM = Read Only Memory - play discs
CD R = Recordable - write songs / data discs
CD RW = Re Writable. - use more than once to write songs / data
What does it say on the front of your drive?
If it says RW or R you need to use a program such as Nero to be able to write discs.
Hope this Helps
Dec 03, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
35 people viewed this question
Alun Cox
