Question about Frigidaire Ovens
I have lost my maNUAL AND DO NOT KNOW HOW TO OPERATE THE SELF CLEANING PORTION OF MY GALLERY BLACK OVEN
  • 8,197 Answers
May I get the make and model # so I can help you more
Posted on Sep 06, 2010
My frigidaire self cleaning oven says F90?
Lift top - there is a quater inch button on the black box behind the door lock - use screwdriver to press the button in - resets
Sep 17, 2012 | Frigidaire 27 in. Electric Gallery Pro...
I need the instruction manual for a frigidaire gallery oven
Here is a link to a website that says the manual is for a wall oven - http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205312en.pdf
Here is the link to Frigidaire manuals as well and maybe you can find the manual there if the first link is incorrect -
http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/
Aug 08, 2011 | Frigidaire 30 in. Electric Gallery Series...
Cant unlock oven door
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Dec 18, 2010 | Frigidaire 30 in. Electric Gallery Pro...
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
F8 / Convection portion of top oven doesn't work
F8 Oven door lock failure Check lock relay and door switches.
Apr 02, 2009 | Frigidaire 27 in. Electric Gallery Pro...
I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Mar 20, 2009 | Frigidaire 30 in. Electric Gallery Series...
Lost manual to my electric oven, how do you clean inside of oven?
Make shure every thing is out of the oven, and that the door is well locked, then hit the cleaning button.
the oven will clean itself with high temperatures.
HEre is a manual for a frigider oven, should be not too different from yours.
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Mar 28, 2008 | Viking VCSO244 Dual Oven
Oven door open
Turn the operating mode dial to self-clean, then manually hold in for about 20 seconds the light pin on the oven rim. The lock will eventually open after 20 or so seconds. Turn off the operating dial and the door will close.
Jan 12, 2008 | Ovens
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
