Question about Philips 42PFL5603D/27 42 in. LCD TV
We have a Phillips 42" LCD and it turns itself off? it happened last year then stopped for about 11 months, the problem has now come back with avengence.
  • 608 Answers
You are not the only one I can tell you that. I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
  • Anonymous Dec 09, 2010
    Solutions?
    Hope this helps
    New Friend:
Philips TV won't come on or goes on and off. FIX IT HERE....Lay Philips 42" Model 42pfl7403d/27 TV down on a blanket or carpet so not to scratch the front. Use T-10 torx driver to remove all screws from the back. Look at power board on left center of chassis, and you will see swollen capacitors. I found three such capacitors on the power board, but I also made a list of all the values of the other capacitors just for future reference sake. There were about 21 capacitors and if you had to replace them all you are talking about $2.50 apiece which is reasonable. Use a 20 to 40 watt soldering iron from Radio Shack , not a soldering GUN which has too much heat. I wrote down voltage and micro-farad (uf) values and purchased three new capacitors. Remove screws and few plug-on connectors from power board, then lift off the board from the chassis. Unsolder old capacitors keeping track of what hole negative capacitor lead goes to. Solder-in new capacitors making sure polarity is correct. Put TV back together and turn it on! This was a $7.29 cent fix I just completed on my mothers Philips HDTV. Time about two hours.
Posted on Oct 29, 2013
My 42 lcd phillips tv colur turns red and zig zag lines then turns itself off why is it doing this
Solutions?
Hope this helps
Oct 21, 2010 | Philips 42 in. Plasma TV
When i turn on the tv , it shuts itself off in 2
Solutions?
Hope this helps
Jan 31, 2010 | Sanyo DP26746 26 in. LCD Television
Magnavox 42 LCD 42mf438b/f7 turns on/off by itself
Mine was doing the same thing. Update the firmware and it fixes the problem. Updating the firmware is done by downloading the file to a thumb-drive from the phillips product support page then plugging in the drive into the side of your television and turning it on. See your manual for slightly better instructions.
Jul 08, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 19" TV shuts itself off.....won't stay on
Solutions?
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Westinghouse 1080P 42" LCD TV - HDMI stopped working
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Apr 10, 2009 | Westinghouse TX-42F430S Television
Tv turns off by itself
Solutions?
Hope this helps
Apr 07, 2009 | JVC LT-32P679 32 in. LCD TV
No picture or sound just six red blinking lights
Use your warranty in a hurry before it expires. Your TV when into protection mode to prevent further damage. Most TVs have a 1 year warranty. Good Luck.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Mitsubishi WS 65513 turns itself off
Solutions?
Hope this helps
Jan 05, 2009 | Mitsubishi WT-42311 42" Rear Projection...
LG TV not turning on
Yes you can get this fixed and it is still worth it. It may cost $200 but it should last a long time.
Nov 12, 2008 | LG 42LC2D 42 in. LCD HDTV
Philips 42PFL5603D/27 42 in. LCD TV Logo
466 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
