Installed for USB, need to install for wifi.
Solution:
- Uninstall drivers and utilities
- connect device via wifi to router (should still be)
- install again. Choose in step 10 of installation process option wireless connection.
should work now.
It's been 8 years since the original post, but the answer is still correct. It worked for a Canon MG8120 with MP Navigator 4.0. I just reinstalled the drivers and software after I got the printer connected to the WiFi, and then everything started working. I should add that my error code was just slightly different: 5,146,55
I believe Canon stated this is a problem with Windows 7. But I did find this fix...
Can you check and see if the scanner work with "Windows Fax and Scan"?:
Start > type Windows Fax and Scan in the "Search programs and files box" and press "Enter" > New Scan
