Question about Irwin Saws
Irwin Industrial Tools 3111001 Carbon Door Lock Installation Kit (Tools & Hardware). Had bought this a year ago -- but ended up buying a door in the frame. But figured we were all set when we went to hang just a door today. Opened the totally sealed Irwin kit package. Followed the instructions. Bored the hole for the knob without a problem. Went to use the small borer for the latch -- its threads don't match the drill bit supplied! We did everything we could think of. There is not a parts list. Was there supposed to be another bit? (We ended up having to improvise with a large drill bit, a narrow chisel, and a knife.) The kit wasn't expensive -- but it only half worked -- so wasted a lot of our time. Aggravating!
  • 35 Answers
SOURCE: Stuck Door Knob with No Access!
I agree with your Hacksaw method. Very easy and very fast. You are going to want to replace the knob anyway so this does not happen again. Just Hacksaw that knob as close to the door as you can without damaging the door. From there you are on your way to access to the parts of the lock. Now you can replace that knob and never have this trouble again!!!! One less headache in Life......Hope this helps you ........Joe
Posted on Jan 10, 2009
  • 22 Answers
SOURCE: Manual lever to lock self clean oven wil not lock
After sliding latch to its locking position did you press the self clean button on the control panel?
Posted on Mar 31, 2009
  • 13 Answers
SOURCE: where 2 buy door seal kit?
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168616
Posted on Oct 31, 2009
  • 187 Answers
SOURCE: Broken door knob, cannot enter room
I know I don't need to mention that knobs with an emergency release inside the house are wonderful things. Many function by sliding a nail into a hole in the middle of the door knob, others use the push/turn technique.
First thing to try is pushing the door knob in and then pulling it out while turning it as far as you can in both directions. If a part is worn out or misaligned, sometimes this is just enough to do the trick. If that doesn't work:
Now that the pins are out of the hinges, try working with another person if you can. Don't concentrate all of your efforts on the latch if you haven't been able to access it because of the moldings. Hinges get sticky and may need a good nudge.
Have one person push the door up from the bottom or top with a small pry bar or large screw driver. While this is happening, watch the hinges. They fit together like a jig saw puzzle, there should be play and they will loosen up a bit now. Now you will have an idea of the best way to try this.
Remember, the hinge side is no longer attached, so caution is in order. If you are working from a side without molding, pull out from the bottom and/or top while lifting gently with the pry bar. You can sometimes use a fulcrum and step on the pry bar if you are alone.
If molding is blocking your side, try pushing the hinge side inward. If that doesn't work, Using the pry bar, go to the bottom corner on the door knob side and tilt the door toward the opposite corner as much as possible.
If you can, jam something as sturdy as possible (screwdrivers)above and below where the latch is. With another screwdriver of tool, push directly into the latch and push the handle of what you are using in the direction opposite the door. Give it a good yank.
Try to be observant and creative while doing this. You are looking to try and squeeze out just a little more space. Use any area where you see play. Underneath, along side, up top, where ever.
There will undoubted be some damage to the wood or paint, remove the molding piece alongside the latch. It will be affordable to replace if you are a diy person.
For the others that commented, parts inside get worn and as mentioned above, the shaft has to be aligned correctly. If not, you run into problems like the latch not fully engaging.
Cutting the knob off will be a bit difficult. Even when that is done, it may be difficult to remove the latch and metal burrs are razor sharp. I think I would call a handyman before attempting that. Good luck all.
Posted on Nov 22, 2009
heatman101
  • 43501 Answers
SOURCE: Oven door latch does not lock - I was told part no longer available
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Posted on Sep 30, 2010
How to install new door lock
For a residential door, you may choose either 2 3/4" (70 mm) backset or 2 3/8" (60 mm) backset. Some locks are not adjustable.
Choose the backset required for the lock. Check the thickness of the door. Standard installation height is 35-36" above the floor.
Bore a 1" diameter hole into the edge of the door and a 2 1/8" hole through the face. A drilling jig helps align these two holes. If you measure and mark the holes carefully and drill accurately, it can be done without a jig, but for about $20.00 the jig helps avoid lock alignment problems or possibly trashing a door. Follow the instructions for the jig and the lock manufacturers instructions.
Jul 09, 2014 | Ace Hardware Ace Door Lock Installation...
Tip
North Carolina Locksmiths NC 800-779-8530 Locks and Key, Do It Yourself...
North Carolina Locksmiths NC 800-779-8530 Locks and Key, Do It Yourself Instruction
http://global-locksmith.com/
Rekeying Locks service, where we provide all your locksmith needs. Rekeying Locks offers services such as emergency locksmith service, rekey your locks, generate a new car key in case you lost your only key (including newer keys with computer chips that require programming procedures), safe diagnostics and combination changes, high security lock hardware such as Mul-t-lock, we replace any type of lock at your location or a complete fresh installation if no lock is currently installed, and many more services as well.
Rekeying Locks service prides themselves on offering the best and most professional service possible. We do the best we can to please our customers and offer them the best solutions for their needs while taking into consideration factors such as a limited budget and time frame. Rekeying Locks service does their best to keep their on-the-road locksmiths as professionally up to date as possible with the most advanced tools in the industry and with the most intense training. Our mobile locksmiths and technicians are prepared to take on any job 24hrs a day all year round.
Unlike some of our competitors in the region we are able to stand by our word on quick response times. We manage to do so with our state-of-the-art dispatching system, allowing us to see the closest locksmith in your area at any given time. We have our locksmiths in key points all over the Global region rather than in one concentrated location. All of our locksmiths have a stock of merchandise to meet almost any request, and should you need anything we don’t have at the moment, we’ll make sure to get it for you as soon as possible. We here at Rekeying Locks service want to help keep our community a safer place to live in, and that means a more secure place as well. All of our locksmiths carry high security locks and hardware which are the most secure locks out there. Whenever you call us to have your locks replaced or even repaired, make sure to ask for information regarding our high security locks.
To sum things up, Rekeying Locks service is here to offer you professional locksmith service 24hrs a day all year round. We look forward to your call and thank you for choosing Rekeying Locks.
RESIDENTIAL LOCKSMITHS COMMERCIAL LOCKSMITHS AUTOMOTIVE LOCKSMITHS
Deadbolt Lock and Key Replacement Car Lock Out
Knob Installation Window Lock Replacement Vehicle Locksmith
Cabinet Lock Replacement Re key and Master Key Install Lost Transponder VAT Keys
Closet Locksmith Safe Lock Repair & Install Automotive Lock Repairs
Safe Lock Repair & Installation Office Lock Replacement Ignition Key Replacement
Desk Lock Repair Replace Mailbox Key & Lock Automobile Lock Out
Master Key Installation Industrial Key Duplication Motorcycle Ignition Repair
Master Key Cutting Office Door Lock Picking Car Lock Out
High Security Cylinder Locks Replace Lost Office Keys Panic Lock Devices
House Lockout / Open Door Locks Store Gate Pas Locks Opened Combination Locks Opened
Garage Lock Replacement Office Door Lock Out Emergency Trunk Opening
High Security Locks Opened Deadbolt Locks Changed Emergency Vehicle Opening
Domestic Locksmith Re keying Master Key Systems Key Cutting
Extraction Of Broken Keys Electronic Keypads Car key Replacement
Peephole Installation GM VAT Key Repair and Install Transponder Chip Key
Intercom Systems Repair & Install Keyless Entry Magnetic Keys
on Apr 21, 2010 | Computers & Internet
Can u show me a diagram on how to wire my blu-Ray to my samsung smart tv
You dont need a diagram. Take a HDMI cable from the blu ray to the TV input. Take note if it is HDMI 1 though 6 and switch to that input to watch it.
Jun 13, 2014 | Irwin American Tool 17105L Carbon Door...
Just installed a Schlage secureKey deadbolt. The key goes in the keyhole but won't turn. The inside works fine - locks and unlocks.
the first thing to check is to take the hardware off the door and check the lock cylinder with the key and make sure the key works the cylinder,, lots of times the tail piece is in the wrong position and will not allow the lock to turn. also - sometimes the latch and the lock are not lined up and bind, preventing the cylinder from turning.
but maybe the cyclinder itself is keyed wrong and if you take it back to the store where you bought it you should be able to swap it out for one that works,, install that one and all should be good.
c...
Jan 19, 2011 | Kwikset Professional Door Lock...
Professional Door Lock installation Kit: After 2-3 years all of the sudden none of our keys...
The lock is bad very common problem with them, If you got 2-3 years out of your "smartkey" lock those things are like dinosaurs most of them don't make it 3 months and this problem happens. Get the traditional pin tumbler version of the Kwikset lock and this will never happen again. Plus it will be an easy swop out since they use the same latch.
May 18, 2010 | Kwikset Professional Door Lock...
How to remove a tumbler from kwikset entry knob ?
You need a kwikset removal tool. Search kwik set core removal tool to take you to a lock smith supply, or try to buy one locally.
Notice, purchase of this tool may not be legal in your juresdiction and MIGHT be considered burgary tools.
Dec 23, 2009 | Kwikset Professional Door Lock...
Change batteries on kwikset pushbotton lock.
If it's the lock I think it is, all you need to do is to remove the two screws on the inside of the door that holds the lock to the door. Pull straight out on the whole assembly. You should see the exposed battery once you have removed the outer case and handle.
Hope This Helps,
RSMITH972278
Nov 10, 2009 | Kwikset Professional Door Lock...
Keyless entry system installation
The esiest way will be to ad an aftermarket central lock motor to your cars drivers door you can buy these seperatly at most alarm shops for a few dollars ,the idea is that you can hook up your ebay kit directly to this motor and this motor will drive the cars central locking.The aftermarket motor hooks up to the lock button rod in your drivers door.You will see this rod moving when you remove the trim and lock and unlock yhe door via the up/down button/knob.
Apr 07, 2009 | Vehicle Parts & Accessories
Lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Mar 07, 2008 | Kwikset Professional Door Lock...
Saws Logo
122 people viewed this question
Top Irwin Saws Experts
Tom Chichester
ray gallant
Are you an Irwin Saw Expert? Answer questions, earn points and help others
