Question about Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive
Missing power cable and
Hello Fixya!
I have the E5 Hybrid Drive Hi-speed 2.0 external hard drive, (model # HD160UHE5-72) 160GB, and am missing the AC adapter and power cord. I have searched Staples, Office Max, Radio Shack, etc and no one has a replacement for this. If you know how and where I can get a replacement part for this drive it would be awesome - there is no obvious link on the acomdata.com web site (in fact, I've been trying to get onto the site but www.acomdata.com does not seem to exist now. Weird.
Thank you in advance!
Skip
  • Anonymous May 15, 2008
    Lightning blew my AC adaptor, hard drive is OK. Mine is an HD160U2E-509
  • lbjones Jul 13, 2008
    i have the same problem. i really need a replacement power cable and i'm going to be very irritated. i don't wanna pay for a whole new hard drive. why do people not sell replacement chords!
  • 304 Answers
Any 12 volt dc 750ma+ power adapter will work.Install the right plug on the end for your external drive. You can go to radioshack and they will have the proper end for your drive. You have to make sure the polarity is right though as it's direct current. The tip or center must be positive. I recommend testing this with a volt meter before plugging it into your drive to ensure proper polarity. I hope this helps you.
George
Posted on Jul 16, 2008
  • George Kohler
    George Kohler Jul 23, 2008
    Please log in and rate this comment fixya if it helped you resolve your problem. If it did not send me an E-mail with
    your phone number to geokohler@gmail.com And I will help you fix your problem. Do not rate the problem until We
    have it fixed.
    Thank you,
    George
    Ps. This is totally free or charge to you. I even pay for the call.
  • William Carr
    William Carr Oct 11, 2013
    The HD160 has a dual output transformer, 12v @ 1.3 A and 5v @ 1.5 so any 12v is not the solution.
Pc does not recognize external drive
External hard drives are plug-and-play devices used to store music, video and data files.
Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
b>
Jan 07, 2013 | SmartDisk Verbatim 96867 2 TB External...
I have a Seagate external hard drive model # 9w6044-500. I need to know what kind of drive it has, how many gigs it is and what size disc it uses.
Welcome to Fixya. Here's the specs of the hard drive
MPN: 9w6044-500
Capacity: 160 GB
Interface: USB
Enclosure: External
Spindle Speed: 7200 RPM
Special Features: Vertical or Horizontal Placement
Internal Data Transfer Rate : 464 Mbit/s
External Data Transfer Rate: 60 MBps
Seek Time: 8.5 ms
Buffer Size: 8 MB
Average Latency: 4.17 ms
Interface (Detailed): USB 2.0
Hot Swap: Yes
Platform: PC, Mac
Height: 2.25 in.
Width: 6.5 in.
Depth: 7.13 in.
Weight: 2 lb.
If you have questions please let me know. Thanks for using Fixya.
Mar 13, 2011 | Seagate (9W6044-500) 160 GB Hard Drive
Dvd drive missing from my computer and dvd drive not locate in bios accer aspire 4520 plz solv my problem
Maybe it's already broken. Have a technician check it first before buying an external dvd drive or get a replacement drive.
Mar 06, 2011 | Acer Aspire 4520-5950 Laptop
I have a 320 GB Simpletech external hard drive in dark cherry with considerable dats and pictures stored in it, but I have lost the cable or adapter that may drive the unit. With the USB cable, the...
You usually get this cable from nearest Bestbuy, Staples or Walmart store.
You can take the SimpleTech SimpleDrive to the store and ask for the adapter and they should be able to supply it.
This way you wont have trouble of getting you wrong part shipped as well.
Thank you for contacting FixYa
Nov 20, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Hi,\r\n When i plug in my Western Hard Disk WD4000ME, its detected by the system and all files are shown, but I cannot copy those files back to the system. It gives the following error:- "The requst could...
An I/O error indicates an issue with the device driver(s) that handle input/output processes such as copying files to/from hard drives, data in resident memory (RAM) waiting to be processed by the CPU or the controller chipset that handles the primary calls to/from the subsystems or a faulty hard drive.
Below are a few solutions that may help resolve the issue and allow you to transfer your files:
Before proceeding, you will need the following:
A. Computer B. External USB Hard Drive C. USB Cable D. RAM Module (Replacement, if necessary) E. Hard Drive (Replacement, if necessary) F. USB Hard Drive Enclosure (Replacement, if necessary) G. USB Cable (Replacement, if necessary)
Note: Solutions B/C apply only to Windows OS.
Solution A. Faulty USB Cable
1. Replace the USB cable. 2. Connect USB hard drive to the computer. 3. Attempt to copy a file from the drive. 4. If successful, copy additional files, as needed. If not successful, skip down to Solution B, step #1.
Solution B. Locked I/O Processes
1. Press and hold the power button on your desktop/laptop for about 10 seconds (or until the system has powered off completely). Then release the power button. 2. Make sure the USB drive is plugged in. 3. Wait another 10 seconds and press the button once again to power on the computer. 4. Once logged in, attempt to copy a single file from the drive 5. If successful, go to step #6. If not successful, skip down to Solution C, step #1. 6. Continue to copy files from the drive. Make sure to pay attention to what files (if any) prompt the I/O error message. If you receive an I/O error, skip down to Solution C, step #1.
Solution C. Motherboard Device Driver Installation/Update
1. Click on the "Start" menu and click on "Control Panel". 2. A new window will open, double-click on "System". 3. A new window will open, click on "Device Manager". 4. A new window will open, listed in the hierarchy are all the hardware components installed on the desktop/laptop. Look for any devices that display either a red "X", yellow "!" or yellow "?". These devices have either incorrect, incomplete or missing drivers/software and need to be installed, as they might be the root cause of the trouble. 5. If any of the above icons are present, perform a Windows Update by visiting the site below:
http://update.microsoft.com
Perform any updates available on the software and hardware side. 6. Restart your computer. 7. Follow Solution C, steps #1-4 to determine if any drivers still need updates. 8a. If updates are not needed, attempt to copy files from the hard drive. If successful, go to step #9. If not successful, skip down to Solution D, step #1. 8b. If updates are needed, you may need to visit the support site for your desktop/laptop's make/model and download any missing drivers. 9. Continue copying files, as needed.
Solution D. Faulty RAM
1. Power off the desktop/laptop and disconnect all cables. 2. Open the desktop/laptop. 3. Remove all the existing RAM. 4. Install the replacement RAM. 5. Power on the desktop/laptop. 6. Connect USB hard drive. 7. Test by copying some files from your hard drive. 8. If successful, close your desktop/laptop and continue copying files, as needed. If not successful, remove replacement RAM and reinstall previous RAM and skip down to Solution E, step #1.
Solution E. USB Hard Drive Case Faulty I/O Board
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install hard drive into replacement USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, skip down to Solution F, step #1.
F. Hard Drive Malfunction
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install replacement hard drive into USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, this could be an indiction of a much larger problem in the form of a Motherboard issue.
If the motherboard is malfunctioning, this is a sign of bigger things to come and will require a replacement board in order to correct.
In the event that the motherboard needs replacement, depending on the make/model of the desktop/laptop, the cost could range from $35-120 for 3rd-party boards or $85-300+ for consumer-level systems from manufacturers such as HP, Dell, etc. and $350-1000 from Apple.
If your desktop/laptop is still covered by the manufacturer's warranty or 3rd-party extended warranty, any hardware component that needs replacement should be covered at little to no out of pocket expense to the end-user. This also includes the external USB hard drive, as well.
Aug 15, 2010 | Western Digital Passport 320GB External...
I have a model HD320UHE5-72 external acomdata hard drive that when pluged into usb and power turned on is not reconized by computer. Vista It worked fine until yesterday.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 18, 2009 | Acomdata E5 HD320UHE5-72 320 GB USB 2.0...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
External hard drive enclosure
I too purchased a Nexxtech Hard Disk Enclosure and my Vista-based computer keeps telling me to try a USB 2.0 setup...the USB's ARE 2.0...did you try the setup disk that came with your unit?...I tried on mine but still a no go...I may have to return it to Best Buy & try somrthing different.
May 19, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Acomdata (HD160UE5-72) (HD160UE572) 160 GB Hard Drive Logo
372 people viewed this question
Top Acomdata Computers & Internet Experts
Jerry Umali
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
