Samsung Q40 Hi, I am trying to upgrade the RAM on my Samsung Q40 laptop, Samsung tell me it sits under the keyboard. I cant work out how to remove the keyboard. Can anybody help me. Thanks Mark
Having the same issue here but not finding a solution, I thought I'd post the answer after testing it out myself!
On the underside of the Q40 are seven screws which are marked with arrows (if you look in the centre of the underside one is marked with the letters KBD so you know what you're looking for).
Before you remove the keyboard, be aware that there is a ribbon connector underneath it, which can be removed, but is stiff and isn't very easy to get back in by hand. You don't need to remove it to upgrade the RAM as it should be long enough for you to be able to work around it, but just ensure that you are careful when you do remove the keyboard as ribbon connectors are easily damaged.
Remove all of these screws to release the keyboard. Open up the screen, and GENTLY lift the keyboard free working from the side closest to the touchpad. Once the bottom is free, slide it toward you and away from the screen to release the two metal tabs securing the keyboard at the screen side.
Now the keyboard is free, jiggle it around until you have access to the memory slot. Ping out the memory by releasing the two tabs either side, and pop in the new chip.
To reassemble, slide the keyboard securing tabs at the top back toward the monitor, lay the keyboard flat, close, turn over, and put the screws back in.
Hope that helps!
Posted on May 21, 2008
  • 38 Answers
Did you check your User's Guide? Nothing there? Information on adding RAM should not be a secret. Ask Samsung for maintenance instructions . . . in English.
It is not a good idea to tear notebooks apart until you know exactly what you are doing.
Good luck.
Posted on May 13, 2008
I want to upgrade the internal ram on a samsung p30 laptop
If it has a second slot, it will be under the keyboard and you will just need to remove the keyboard. Typically there will be 1-3 screws on the back of the computer labelled with a K, and or you need to pry off the bezel on the front above the keyboard which also may have screws on the back holding it in place. Along the the top of the keyboard under some keys you may see holes, these are pry holes. Be careful though it is easy to break clips.
Jul 09, 2012 | Samsung P30 Notebook
Hi, I would like to upgrade the original 512 MB memory. We have just found the second slot (just under the keyboard!!!) and now I have the following question: can I keep the old 512 MB RAM module and...
What type of RAM is your Pc using? SDR, DDR1 or DDR2? 1 GB single module of RAM maight be heavier for your notepad and the Laptop maight even fail to boot. Just use the 2 Modules of Ram (2 chips each 512MB) and check in BIOS if the RAM capacity has acually changed.
Nov 04, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Cant find ram chips in a Toshiba Satellite A45-S151
The memory is under the keyboard on this laptop. You should be able to pry up the keyboard with a small screwdriver between the keyboard bezel and the keyboard itself.
Be very careful not to break the wires connecting the keyboard to the internals of the computer.
I hope this helps.
Feb 22, 2010 | Toshiba Satellite A45-S151 Notebook
Memory Upgrade
Here is how to upgrade ram on E-System 3086/Advent 8109 laptop.
Mar 27, 2009 | Toshiba Satellite A85-S107 Notebook
I can't find the second ram slot
Lots of laptops have the second slot under the keyboard. If you are adventurous take the keyboard off and look in there.
Mar 11, 2009 | Evesham Computers & Internet
Memory uprgrade
You have to remove the keyboard, under the keyboard to the left is a heat shield (silver metal cover), remove it. Your ram is located there. Just take your time and remember where the screws go.
Jan 22, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Accessing RAM slots in toshiba satellite A40 laptop
Click on never installed memory? warch how, then click on laptop and watch video. Enjoy
Jan 17, 2009 | Toshiba Satellite A40-S161 Notebook
Cant install two emory modules as can only find one slot!
I hope you have not gave up on your problem. Your Notebook is equipped with two memory module slots. One slot is user accessible ( under the notebook) , the other slot sits beneath the keyboard under a EMI shield (Electromagnetic interference Shield). All it requires is the removal of the panel where the power button is at and two screws that hold in the keyboard. If you are uncertain of performing this task, any local Certified computer shop can perform this in 5 minutes.
if you think you can tackle this task it is not hard and i have detailed photo's if you need them.
Jan 09, 2009 | Toshiba Satellite M105-S1021 Notebook
Ram change on Packard Bell easyone 2120
Memory Upgrade Instructions
128 MB SDRAM on-board, max. 256 MB upgrade (384 MB total), PC-133
Remove the memory module according to these steps:
1. Turn off system power.
2. Remove the battery and disconnect the AC-adapter.
3. Open the top cover.
4. Press the locking latch downward to unlatch the Easy Start panel.
5. Then push it leftward and lift it up from the left side.
6. Slightly lift up the keyboard and disconnect the cable from the system board to free the keyboard.
7. Pull the retaining clips outwards (1) and remove the SO-DIMM module.
Keith Stoffer
Comptia A+ Certified Technician (20+ years)
Oct 30, 2008 | Packard Bell Easy One Silver 2120 Notebook
Medion MD41349
You need to remove all the screws from the back also, then remove the cover to the rear on the bottom and remove the wireless card (make note as to connection colours) and there is 2 (I think) screws under there, then one also under the battery, then the whole top opens up.
Make sure you have removed all screws from the bottom case, including the four under the rubber feet at the rear.
This was the most awful laptop I have ever worked on!
May 11, 2008 | Medion MD-40954 Notebook
Computers & Internet Logo
501 people viewed this question
David Payne
David Payne
