Question about Garden
Unable to remove hub 02438900 to replace bearing on ariens 1128 snow blower. This is the pully/hub that controls the auger.
  • 84 Answers
I also had this problem. I actually pulled the ears off of the hub using 2 different pullers. I ended up heating the hub and hiting the shaft through the hub with a small sledge. It took 45 minutes. Then I tried to remove the impeller from the shaft. Not a chance! Both pins out but it would not budge. This is a customers machine and it needed a gearbox. I'm going to end up putting an impeller on it as I can't get it off the old shaft.
Posted on Dec 07, 2010
  • RPM Small Engine Repair LLC
    I soaked the shaft in PB blaster for two days and then continued heating and hammering the shaft. It finally came out of the impeller. WOW
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
932 ariens shuts engine down as clutch is engaged to throw snow
Your problem would be in a safety shutdown switch.
some Ariens blowers have a two handed safety switch whitch is located on back of blower right lower side (inside of body)
You have to remove 4 transmission pan bolts to see it.
The other location is under the metal face plate between the handle bars.
Some of them have a third handel on right side of handle bars that has to be depressed to run auger .
Mar 01, 2014 | Ariens Garden
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Ariens st350 snow blower wont blow snow, augers wont spin
there is a bolt that goes thru auger and spinning shaft (look for a hole where it once was) holds the augers to the spinning shafts, it is called a shear pin, it is a safety feature, and made of softer metal, so if you pick up something too hard with the auger, it wont lock up the engine, or break engine crank shaft.find an ariens repair shop to purchase the shear pin so you get the right softness of metal.
Mar 05, 2013 | Garden
Only one blade turns automatically on Ariens snow blower.
There is a bolt that goes through the center of the shaft that shears off if you hit something. You will need to line up the holes of the internal shaft with the auger tube and install a new bolt.
Feb 09, 2010 | Ariens 34 In. Zoom Series Riding Mower
I have a ariens snow blower model 1128 when i engage the impeller turns and the shaft to the auger gear box turns but the augers don't turn. the shear bolts are not broke either
Have you confirmed the bolt integrity completely through the shaft? Also check the gearbox for proper lubrication or gear failure.
I recommend contacting your nearest authorized service center, or you can download operators and service manuals typically online by performing a simple Google search using your make, model number and part needed.
Downloadable Manuals
I trust this information proves beneficial.
Jan 02, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
557 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
