Question about Refrigerators
We have a leak under the fridge and not sure where it is coming from. We do not have an ice maker hooked up. Thank you Chris
  • 50 Answers
Hi Chris. There is a pan on the motor in the back of the fridge. There is a plastic pipe coming out of the fridge near there as well. Check that the pipe runs into the pan. This is the run off from in the fridge which goes into the pan, where the heat of the motor evaporates it.
Posted on Sep 06, 2010
Why is aSide by side fridge leaking brown liquid from below ice maker?
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Ice maker leaking water into ice bin and not making ice fast enough.
Replace the Icemaker Water valve in the bottom rear of the Fridge. Its the part the water line hooks to.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 20, 2011 | Hotpoint Refrigerators
Rs2556sh model leakes water under fridge when ice maker cycles
If there was water in the water line it could have split. Check on the back where the water line goes from the inlet valve to the ice maker.
Oct 01, 2009 | Samsung RS2630SH Side by Side Refrigerator
Water always leaking out from bottom of fridge
If you have a ice maker check to see if the leak is coming from where the water connects into the back of the frig. If you dont have a ice maker. Look under the frig and be sure that you have a drain pan in place.
Aug 15, 2009 | Hotpoint Refrigerators
Water is leaking into fridge, ice maker making hollow ice
Make sure when the icemaker fills its not causing the leak ...... other than that you have a clogged drain in the freezer section .... easiest way remove everything unplug for 24 hrs with door open .... manual defrost ....hehehe ..... plug back in u should be ok if reoccurs call for service
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from under the refrigerator, ice maker and water are NOT hooked up to refrigerator.
If no water is hooked up to the fridge then the leak is condensation. Check behind the fridge and make sure the drain hose is not plugged and that the pan is empty and clean. Make sure to disconnect power before servicing.
Jul 14, 2009 | Refrigerators
Water leaking into the fridge. I think it is coming from the ice maker. If I turn the ice maker off inside the freezer, then the water problem is worst. So, is there a way to cut of the supplier of...
There should be a cutoff valve on the line going to the fridge. This will cutoff water dispenser, as well, if it has one. It may be behind the fridge or under the sink, or???
More help?, let me know.
May 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
