Question about Fisher and Paykel Washing Machines
I have a F&P smart drive 051. I replaced the solenoid removing the panel and the blue box inside to do so. I have replaced the solenoid and reinstalled the top end however now find that the unit will not spin. It was fine before I touched it? Is there a simple fix for this. Is the spin in some way controlled from inside the control panel?
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Does the machine drain the water?Does the machine wash.Does the machine beep and show an error code?Have you checked all your connections?Why did you replace the water valve?Did you replace it with a 12 volt valve like the original?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Posted on Sep 07, 2010
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Tip
Automatic trasmission lever is stuck in park position
When this happens, usually it is because of a failure in the gearshift selector switch solenoid.
The gearshift selector solenoid is the switch that unlock the lever from park position when driver turns on the ignition and release brake pedal.
When brake pedal is depressed with selector in park position, this energizes the solenoid, unlocking the shifter.
Teh solenoid is energised by same circuit connecting the brake lights.
When for some reason (a short for example) the brake light fuse that protects the circuit blows, this will result in a failure to energize the solenoid, and lever won't be released from park position.
You find the fuse in the fuse box, on Discovery this is fuse number 1. This is a 15 Amps blue fuse. Fuse is located in the fascia fuse panel.
In most cases you fix the problem by replacing the brake light fuse.
Another reason for a failure to energize the solenoid is a faulty brake light switch.
This means the solenoid itself is faulty and need to be replaced.
How to proceed:
Check brake lights. If brake lights are not working, check and replace fuse number one in the fuse box. This will solve the problem in most cases.
If fuse keeps blowing there must be a short in the brake lights wiring.
You will need to access the rear light access panels and unplug the wiring harnesses that connects to the tail light assemblies.
Replace the fuse and try again to start the car, with all tail lights harnesses disconnected. If it starts drive the vehicle to the nearest mechanic, the vehicle will not be safe without tail and brake lights.
When fuse is not blowing check the brake light switch. Remove the panel above the brake pedal. There you find several switches, the second from the bottom will be the brake light switch. Unplug the switch connector, put parking brake on, turn on ignition and short the two green wired pins.
You should hear a click, while shorting the contacts move the shifter out of park position
When brake light are working fine, and lever stays on park position, it is usually the solenoid or its connections that are faulty. Try connecting directly the solenoid to power. The solenoid is connected to red and black wires. Apply 12 Volts across the wires, following polarity. If this worked the solenoid will click, and you will be able to move the gear out of parkposition. When there is no click you need to replace the faulty solenoid that is located in the shifter assembly.
on Aug 26, 2008 | 1998 Land Rover Discovery
Im looking for the color codes for the shift interlock plug connector thats for the column shifter of a 2010 f150 xlt this plug has 5 wires, black/white -- white -- brown/green -- green -- ...
If your truck is equipped with a column shifter the shift interlock solenoid has a three pin connector. The wire colors are Black/White (ground), Blue/White (Battery voltage via "Smart Junction Box" in right kick panel), and Green (input circuit to Instrument Cluster)
Jan 09, 2011 | Ford F-150 Cars & Trucks
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
My fisher & paykel smart drive 051 will wash then drain, but when it gets to the spin cycle it wont spin at all it fills then drains only.
Possible that the program controller is faulty and is not executing the output when the wash cycle and the drain is done. So the program must advance further to the next stage to drive the motor to spin after the water is pumped off and the water level sensor is reset.
Have the conttroller checked to confirm the fault, look for loose joints in the connections.
If not the controller can be a suspect.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Mar 31, 2009 | Fisher Washing Machines
Washing Machines Logo
87 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
