Question about Compaq Presario 5000 PC Desktop
Computer power problem
When i switch the computer on the light turns orange and nothing happens
  • Anonymous Feb 22, 2009
    when i power on the CPU computer doesnt start, no display in monitor.
    but when swithcing on frequently , the computer starts successfully.could not diagnoise the problem
    {i have the same problem, the mother borad power is on, fan is running and no beep sounds,power leds are ON, no display in mother board.}
    The service people changed the mother board bios chip, repaired the SMPS but still the problem persists.
    Scholar:
  • 160 Answers
For solving your problem do the following:
1. Check that the power cable is connected properly to the monitor
2. See that the SMPS of the CPU is working
3. Check that the power output from the SMPS is upot 12V
If not change the SMPS it may be due to failure of SMPS.
Let me know if your problem is solved and rate me as FIXYA!
Posted on May 16, 2008
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
Alarm beeps and orange light flashes when power is switched on.
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Feb 15, 2014 | HP Pavilion Computers & Internet
No power only orange power light
Hi, It most likely is a faulty power supply or a motherboard issue. Remove the power cord then press and hold the power button for at least 30 seconds. Then plug it back in and hit the power button. This will release any static buildup that might be in the computer and sometimes that causes it not to boot. If nothing is happening it is more likely your power supply than the motherboard.
Mar 19, 2012 | Dell Inspiron 530s Desktop Computer...
No display
try this ,unplug power cord turn off computer, (if you have switch) there should be no electricity. Remove little battery that you have on your board,wait for 10 sec. and pull it back in, that will restart cmos to default values.PLug power cord, turn on computer. Post me what happened.
Jun 09, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
My Laptop does not turn on.
That orange light is usually an indication that the battery is not working properly. If you turn the computer on and take the battery out and put it back in it the yellow light might turn off. There is another indication that you have something in the power settings that might need to be set properly. Check in the control panel>power settings and see if the battery and power settings are okay. Also, sometimes the mute on the volume might be on. Lastly, I had a laptop that never turned on and when the hardrive was taken out and the power was turned on it still did nothing until it was turned off and the harddrive was put back in then turned on again.
Nov 05, 2008 | Acer Aspire 5100 Notebook
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
Power button won't turn monitor off?
ok,your monitor is in  a very simple problem.clean the control panel circuit of your monitor,or if it is not working replace the tact switch in your monitor.
Oct 18, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
Compaq Presario 5000 PC Desktop Logo
124 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
