Question about Whirlpool Duet GHW9150P Front Load Washer
MY DRYER WONT TURN ON AND THERE IS A SETTING LIGHT ON IN AUTO CYCLE, MANUAL CYCLE AND TEMPARATURE. i TRIED HOLDING DOWN THE UNLOCK BOTTON FOR MORE THAN 30 SECONDS WITH NO LUCK. i HELD DIFFERENT COMBINATIONS OF BOTTONS DOWN BASED ON SUGGESTIONS ON YOUR WEBSIGHT WITH NOT LUCK AND TURNED THE BREAKER ON AND OFF. pLEASE ADVISE.
  • roe712 Sep 06, 2010
    iF YOU READ MY EMAIL i SUGGESTED THAT i DID THAT AND IT DID NOT WORK
    You are right I called it the unclock button but I would think you would have known what I meant since that is the typical suggestion on your websight and I did state that I tried all the button holds that were suggested in your websight and that is mentioned about a zillion times. dI feel like I have just been ripped off for $.18.00
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this and unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 06, 2010
  • Rylee Smith
    Rylee Smith Sep 06, 2010
    In your post its not written anywhere that you have already tried holding the END OF CYCLE button, if still the issue is not resolved then you'll have to replace the control.
  • Rylee Smith
    If you want to replace the control yourself let me know so that I can provide you with a repair manual.
On and off
Turn off the Auto start function by holding it down 6 to 8 seconds. Refresh the startup and go from there. See page 17 in the manual.
Feb 10, 2014 | Keurig Elite B40 Coffee Maker
Samsung DV210AGW/XAA Dryer, drum wont turn nor heat up
hi all, thanks for your comments. to note, it's my dryer not my washer so the suggested solutions wont work. Also, forgot to note, the unit is only 14 months old and just out of warranty. What I've done so far:
- vacuumed the filter
- striped the dryer, meaning removed top. front and small exhaust panel in the back
- vacuumed everything
- checked the belt, tight, not loose, broken or off the roles
- child safty not enguaged, toggled it anyway to be safe
- the checked micro switch next to belt by motor, not engaged
put it all back, turned on with nothing, tried every setting in auto and manual tied high to low temps and times, the time is noted, such as 40 min, but does not time down, over time, the unit sound the I'm done tone, if left as is, continues to chime then end like it did something. all along, the drum never rotated nor did it heat up.
Does one impact the other, such as if the drum does not roll then the heater wont start or vise-a-versa. Could the control panel have taken a hit or are there sensors that might have shut down to prevent the unit from starting are there fuse's that I didn't see that might have been tripped.
Jan 04, 2013 | Samsung Washing Machines
The control button on the Whirlpool Duet Dryer is permanently on. As a result, we are not able to start up dryer. We have unplug dryer for 5 minutes with no positive results. We have also tried holding...
Hi
Press and hold the CYCLE SIGNAL/END OF CYCLE button for 10 seconds to unlock the controls. Hope this helps...please post back for further assistance.
Daniel
Jun 11, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Control lock light wont go off cant wash or anything even tried to unplug
Press and hold 'dry' & 'spin' that should unlock OR Try holding the "end of cycle" button down for 5 seconds.
Jul 30, 2010 | Kenmore HE3T Washer
Control locked on my Whirlpool Duet GGW9250PW0.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
(Tip Courtesy JSRock)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 22, 2009 | Whirlpool GEW9250 Electric Dryer
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I...
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I plug it back in the control lock light come back on. Whirlpool Duet gew9250plg
Aug 05, 2009 | Whirlpool GEW9250 Electric Dryer
WHIRLPOOL DUET GAS DRYER CONTROL LOCKED ON.
Hold down the end of cycle signal botton for three to five sec that should turn that off good luck
Apr 11, 2009 | Dryers
Hotpoint wd420 washer dryer door won't open.
Press the start cancel button for at least 2 seconds, switch off, leave for 2 mins,switch on again holding the botton for 2 secs, then press start cancel buuton again for at least 2 seconds, hope fully ,this should do ths trick.
Thanks
Plz rate my solution
Jan 22, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Electric dryer timer
the auto temp sensor is bad / Larry
Nov 01, 2008 | Kenmore 62602 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
