Question about Proform XP 580 Trainer Treadmill
How do I take it apart? It won't fit through my doorways ...
How do I pull apart st3352 treadmill to fit through doorway?
tip it on its side and put the handles through first and then maneuver the base through after
tip it back right side up when in the next room
May 31, 2016 | Exercise & Fitness
What is the easiest way to take apart the machine to be able to fit it through my front door and bring it inside my house
many will go through a doorway without dis-assembly turn on side and work it through .
Jul 23, 2015 | Exercise & Fitness
I am purchasing a sofa that is 130'w x 65'd x 40'h and the room is 11'8 x 13 in size. Will the sofa fit?
How wide are the doorways? The sofa will fit against either wall, If you can get it through the doorway.
May 22, 2014 | Furniture
Need to take apart and move my reebok 8000 es treadmill
you to dissasembly read your instruction manual and proceed download from www.fitness.manualsonline. or www.iconservice.com
Jun 22, 2012 | Reebok 8000 ES Treadmill
How do I move my Proform Treadmill to another room without taking it apart completely. It will not fit thru the doorway and too heavy to lift alone.
I have moved this treadmill several times since we bough it. Up and down stairs and from one room to another. I also used to be a mover so I hope this helps. I am not sure what model you have but i have the 525x. To move it I make sure the incline is set to zero, list the track/running section and lock it into place with the locking pin located on one of the handles. The Proform i have has attached wheels so i lean it back and get it close to the door standing straight up. Once there I turn the treadmill slightly and get one side through the doorway then I pull it halfway through the doorway. If its a tile, wood or linoleum floor make sure to put a rug under the treadmill to protect the floor. It will also helo it slide through the doorway easier. Then tuun the treadmill slightly the other way and get the other half through the door. Once there i tilt it back on its wheels and move it where i want it.
Jun 18, 2010 | Proform Crosswalk 500 Treadmill
Get Life Fitness 9700 generation treadmill through doorway
You need to remove the upper console arms/assembly - unbolt the five or six large bolts holding the frame to the base (you will need to remove the motor hood) and unplug the cable from the circuit board that goes up inside the arm to the console (make sure the power is unplugged!) use a 3/4'' ring spanner or socket.
Sep 01, 2009 | Life Fitness 9700 Next Generation...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Proform XP 580 Trainer Treadmill Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
