Question about Balance CN6555 Notebook
CAN YOU INSTALL A WIFI CARD FOR WIRELESS CONNECTION
    Guru:
  • 689 Answers
You can on some of the recent netbooks,find out spec first thereare a/b/g/n n is the most recent,
search net for compatable model or conust manufacturers hotline for recommended model and brand
mine is quite small and is held in with two screws
Posted on Sep 06, 2010
Dear Sir, There is no provision of fixing my laptop to a wireless router.Can anybody advise how to convert this laptop to enable getting wireless connection of internet?
There's a lot of available wifi adapters out there that you can just plug into your laptop's usb port. You can try looking them up online or in computer shops.
Jul 29, 2011 | Computers & Internet
Tip
How to Connect a Laptop to a Wireless Router
  • 1 Purchase a wireless router that fits your needs and price range.
  • Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • Click on "Properties."
  • Select the "Wireless Networks" tab.
  • Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Avable Networks" section.
  • Click on "Configure" when you see your network's SSID in the "Available Networks."
  • Enter your network's SSID and WEP key.
  • Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • on Oct 08, 2010 | Computers & Internet
    I can't figure out how to connect to the internet with my Belkin card.
    this is wireless (wifi) receiver
    the first you need is wifi connection around your computer
    if there any wifi connection aroud you, at your computer open and search the available wifi connection, then chose connect
    and you can connect internet after you connect your belkin to wireless connection
    Mar 25, 2011 | Belkin (F5D7011) 802.11g/b Wireless...
    How to connect new laptop to router
    Hello
    Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    Hope it helps, if so do rate the solution
    Good luck
    Dec 24, 2010 | Linksys Wireless-G WRT54G Router
    I have installed Connectify on my Windows 7 laptop. The Connectify network shows up for the ipad and it says it's connected, but no data flows. iPad does not have a working internet connection (using the...
    If you want to use the same connection from at&t ..you have to download and install the AT&T communication manager for windows & ..and after that make the connection ..
    Here is the link ..
    http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/communication-manager/index.jsp
    If you have the AT&T on a wireless router ..use the wifi .card to connect to the router ...by ..enabling the wifi ..than click on the card icon ..and scan for networks ....When the router is found by name ...click connect ..and thats all..
    Dec 26, 2010 | Computers & Internet
    How to install my router for wireless internet on my laptop.
    1. Purchase a wireless router that fits your needs and price range.
    2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
    4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
    5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
    6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
    7. Click on "Properties."
    8. Select the "Wireless Networks" tab.
    9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    10. Click on "Configure" when you see your network's SSID in the "Available Networks."
    11. Enter your network's SSID and WEP key.
    12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
    Thanks.
    Have great day.
    Oct 01, 2010 | Computers & Internet
    I dont know how to connect it to my laptop wireless
    Aug 01, 2010 | Computers & Internet
    Cannot connect to internet with konaki netbook
    How to Connect a Laptop to a Wireless Router Using a Windows Operating System
    Follow the router's manual to set up the router and its Internet connection , which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    Dec 12, 2009 | Computers & Internet
    Wireless network setup
    Based on your post, you currently have a working Netgear WiFi Card installed in your laptop. What you want to do is remove it from the laptop and install the said card to your desktop.
    For your desktop to be able to accept the NetGear WFi card which is a PCMCIA Cardbus device, you need to install either:
    1. a USB Adapter for PCMCIA as shown here; or
    2. a CardBus/PCMCIA to PCI Adapter Card available here.
    Either one will work. Of course you need to install the necessary drivers for the NetGear MA701NA in your desktop which is available from the CD installer that came with the NetGear or online here.
    Considering the cost of the USB adapter or the PCMCIA to PCI card, you may want consider buying a PCI WiFi card or USB WiFi dongle.
    Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
    Good luck and kind regards.
    Nov 15, 2007 | NetGear (MA701NA) 802.11g/b Wireless...
    WIFI
    Sounds like one of these problems.
    1) The wireless hardware is turned off in the BIOS. Reboot and check to see if there is an entry in the BIOS for the embedded wireless card and if so make sure it is set to ON.
    2) The hardware is not recognised because the drivers are not properly installed. Check in DEVICE MANAGER to see if the wireless appears at all, and if it is in an error state. If so, re-install latest drivers from the manufacturer's web site.
    3) Other software necessary may be missing. Some machines have wireless manager clients that they need to access the card. Check on the manufacturers' web site for these utilities, and if found, install them and reboot watching for new (different) problems to arise.
    4) You could have buggered wireless hardware, but this seems pretty unlikely. Some wireless cards are add-ins and can be removed from the laptop motherboard by accessing them through a door on the bottom of the unit. If that is the case with your machine, power down the unit and remove the wireless card. Check in the hardware manager to make sure no device errors for the card remain, and if they do, remove the hardware by right-clicking on the error device icon and clicking on REMOVE HARDWARE. Then, power down and re-insert the wireless card and reboot and try a clean install.
    Good luck...
    Nov 14, 2007 | Acer TravelMate 3012WTMi Notebook
    Balance CN6555 Notebook Logo
    18 people viewed this question
    Top Balance Computers & Internet Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Jaime Hernandez
    Jerry Greenberg
    Jerry Greenberg
    Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
