Question about Ricoh Office Equipment & Supplies
Ricoh ap3800c, I am getting a series of paper jams, they are type A. Ie they occur in the transfer belt area and partially exit inside the side compartment. I have changed the paper to a heavier type, I have replaced the trasfer unit with no improvement. Is there anything that can be done?
  • 155 Answers
Try to clean the paper feed rollers, if this return call the technician to check the paper feed clutches. i think the secondary feed clutch is loosing the grip to transfer the paper up to the fixing unit.
Posted on Sep 10, 2010
Sc559 for Ricoh MP 2000
Jam error detected 3 times in succession 559 1. The exit sensor and the duplex sensor detect a paper jam 3 times in succession 2. This condition can occur when SP 1159 1 is set to 'on'. The default is 'off'. Paper jams can occur for the following reasons. 3. Dampness 4. Paper curl 5. Incorrect paper setting in the paper tray Stripper pawls coming apart
Dec 12, 2015 | Ricoh Office Equipment & Supplies
Phaser 8860 prints only on left side of the paper, leaves perfect image on drum of right side.
Dear
As per your statement the image formation on drum is ok but prints partial on paper.
The image from the drum is picked by ITB (Inter Transfer Belt) which is a thin plastic like material and the paper passes in between the transfer roller and ITB.
If the ITB unit is not properly aligned to the transfer roller or to the drum the problem will occur as you mentioned. Also check the transfer roller and it contact path.
Thanks.
Jan 13, 2015 | Xerox Phaser Office Equipment & Supplies
How to solve error SC471 on my Ricoh 3800C
That is a transfer belt lift up error. The transfer belt lifts up for color and goes down for black only prints. Open right side door and check for paper stuck in the area near black rubber roller. Sometimes the belt dosen;t lift correctly. Open front door and turn knob on upper left counterclock wise to lower black transfer roller. On brown cover remove the top left screw and bottom right one (need to look on bottom side of cover) Slilde transfer unit out then back in. It is also possible the sensor inside machine is dirty.
Aug 18, 2009 | Ricoh Office Equipment & Supplies
Ricoh MP 5000, says it has a paper jam, but I can't phyicial see a jam, wont print, scan, copy, or fax
if the jam still shows when you turn the machine off and on then you will have to look first to see which tray you were using at the time take the tray out and look inside the frame to see if paper has stuck by the feed rollers then open the side paper path guide to check non is on teh way up from there the next is reg transfer and fuser sections also pull the duplex out to make sure its not under the travel plateand last is to check betweent ehfuser exit and finisher opent he dooor on finisher if you have one and lift the plate at top right had the paper can sometimes be hidden there... failing that the sensor for the paper exit from fuser to duplex can sometimes jam a small bit there...if you know how to get into the sp modes you can go to data log 1 there you have the jam counters and jam history look at latest and the area will show up where it could be last. good luck A..
Jun 26, 2009 | Ricoh 4506 Copier
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
Feb 27, 2009 | Ricoh Aficio AP3800C Laser Printer
Paper Jam from the duplex into the Main Unit
Sorry dude, not my thing, great with epson, canon, hp, lexmark, brother but not ricoh
Dec 11, 2008 | Ricoh Aficio AP3800C Laser Printer
I Have image registration
bad transfer belt(the transparent one under the drums )
Nov 08, 2008 | Ricoh Aficio AP3800C Laser Printer
RICOH AFICIO AP3800C
This normally suggests to the transfer belt it is possibly worn and the transfer unit will need replacing
Hope to be some hep
Jan 02, 2008 | Ricoh Aficio AP3800C Laser Printer
Fusing belt damage
You should be able to buy the part from a Ricoh dealer - it's a part as opposed to a consumable. There are, however, two issues to take into account: 1) It costs nearly as much as a complete unit to buy 2) They are really tricky to fit.
I suspect you have used the old oil supply unit in your new fuser. If so the problem is probably there.
It may be that the paper jam has broken one of the upper fuser fingers. In the past I have removed these and the fuser has worked fine. You may find you get the occasional rap around but it should be a rare event.
Nov 21, 2007 | Ricoh Aficio AP3800C Laser Printer
52 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
