Hi, On the display on the washer it reads "door" What does this mean please? Geoff
  • 50 Answers
The door is either not closed or the microswitch that tells the machine it is closed is broken.
Posted on Sep 06, 2010
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
When i put the waashing machine on it comes up dE can you tell me what it means please
Hi.
Small d and E means door error. Big DE is drain error.
Hi.
To start be sure that it is small dE , like this:
If it is a big D, then it is drain error, like the one below:
Washers have a door lock with micro-switch or a door lock motor, depending on the model.
If there is a door switch, this can be tested either reading Ohms or jumping its contacts. When the switch has three contacts instead of two the third contact is an 'heater' (impedance). With door closed the two (or tree) door switch contacts must show continuity, which means that if you read impedance using a multimeter the impedance will not be Ohm infinity (circuit open).
If there is a door motor and no switch the motor is tested reading Ohms and verifying that they correspond to the value in specifications.
If it is door error check the connector to the switch or the
(usually VIOLET(VL) 2 PIN on LG) connector to the power board. Disconnect power first and read impedance to check if there is contact.
Regards.
Ginko
Aug 08, 2011 | LG Washing Machines
When i try to start the washer code d5 shows ands chimes
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Washing Machines
Hi - my washer machine stops mid cycle then beeps and shows a dL code. what does this mean? How can I fix this?
Listed below is the meaning off the error code, and corrective actions needed.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 05, 2010 | Hoover H130E Front Load Washer
What does code F DL code mean?
Hi
Thanks for using FixYa. Error FDL means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
It has occurred due to
1. Door lock mechanism is broken or removed from door.
2. Door switch/lock unit failure. To unlock it follow the steps—
a. Unplug washer or disconnect power.
b. Check door switch/lock unit.
c. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Please do rate the solution if issue is resolved else post a comment for assistance.
Thanks
Rylee
Jul 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite smartwash flashes f and dl when i try and run the wash cycle
Hi
Thanks for using FixYa. Error fdl means a Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Please revert for further assistance.
Thanks
Rylee
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Apr 18, 2009 | LG WM2487H Front Load Washer
Whirlpool duet 9400 Washer won't do anything?
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
The front light lit on my Whirlpool.
Regards.
Dec 27, 2008 | Whirlpool GHW9400 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
