Question about Conair Health & Beauty
I took the blade off my Model GMT182XCS/TXCS trimmer and I may have gotten the blade turned around. I tried to put it back on both sides of the plastic part that contains the wire but I can't seem to get it back so that the screws will go in securely. I need a diagram of how this fits together properly.
askmannyssha
  • 76 Answers
SOURCE: does the Wahl Model AC Trimmer have an adjustment
Wahl has two type of blades for this AC trimmer, some come with a fix blade no adjustment,the other type of blade has adjustable blade. Wahl dose market the blade as adjustable or non adjustable. But mannyssharpening.com has the adjustable blade type were they can adjust the blade for a close cut.
Posted on Mar 30, 2010
askmannyssha
  • 76 Answers
SOURCE: took oster blades apart and now don't know how to put them togeth
First thing about Detachable clipper blade are Tension and straightness, You need a special tool to set the tension on your blade and the spec's on how much tension, plus you need to set the straightness of the tension spring. With out these tools your blade will not cut, even if some body sharpens the blade and do not set the tension correctly and straightness. You need to send it to a professional sharpening company, mannyssharpening.com has a mail order service he charges $8.00 to sharpen set to factory spec's and this price includes return shipping, they are fast in service.
Posted on Apr 18, 2010
SOURCE: Have Oster model 23-51f fast feed trimmer. Took
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Posted on Feb 01, 2011
SOURCE: i need the white plastic piece that fits behind
Call this # 800.326.6247
Posted on May 12, 2011
SOURCE: I have a Wahl Designer
Check out my video on how to install a Wahl Blade this may help you. Manny's Sharpening.com
Posted on May 15, 2011
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
The trimmer is not cutting the way it should, the bottom blade seems out of place and I cannot put it back in place
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Oct 05, 2010 | Conair HC100RCS Hair Trimmer
Have Oster model 23-51f fast feed trimmer. Took the blade off havinv trouble putting parts back together namely small copper plate approx. 1-cm long, also having trouble getting the blades to fit together...
Sep 22, 2010 | Oster 76915016002 Hair Trimmer
I took it apart to clean it but, like a dummy cannot put it back together. dog trimmer model 9765
Your style came with a DVD, can you find that??? I just can not find a manual that is in print form to assist you, sorry!!! Guy
Sep 12, 2010 | Wahl 9765-301
Can i sharpen my electic trimmers using sandpaper
Things You'll Need: Three-sided blade sharpener (coarse, medium, fine) Small flat head screwdriver step 1 Using the flat head screwdriver, unscrew the trimmer blades and remove them carefully. Wipe off any oil, grime or dirt that has built up on them as this may make it more difficult to handle and keep them in place during the manual portion of the sharpening process. Step 2 Separate the blades and re-apply only the moving blade to the tension spring. Then apply the moving blade to sharpener surface and turn the clippers or trimmers on. Hold the moving blade on the surface of the sharpener and apply light pressure while moving the blade back and forth for one to two minutes. You can also lay the blade on the sharpener first, then put the trimmer tension spring directly on the blade. Step 3 Turn off the clippers and remove the moving blade. It should look shiny and feel sharper. Step 4 Remove the guide from the guide blade by unscrewing it using the flat head screwdriver. Place the guide blade on the sharpening surface and manually run it back and forth for about one or two minutes or until it's been sharpened to your satisfaction. Screw the guide back onto the guide blade while being careful to readjust it before you tighten the screws. Step 5 Screw all the blades back on the trimmers and power them on to make sure they've been fitted correctly. Test them on your own hair to make sure they've been sharpened correctly and are set to the desired depth. Ads by Google Best Knife Sharpener Sharpen like the pros. Complete kit w/ 1x30 belt sander. Only $189.00 www.theedgemasters.com Braun® BodyGrooming Tools Try the Braun® bodycruZer? with Gillette® Fusion Razor Technology. www.Braun.com/BodyGrooming Oster ® Clipper Blades Oster ® Full Line Clipper Blades, Animal & Human Oster ® Blades. www.HouseholdAppliance.com STIHL Electric Trimmers Buy it. Plug it in. Trim it up. Depend on STIHL Electric Trimmers. www.STIHLdealers.com Tips & Warnings Which surface you choose, whether coarse, medium or fine, depends on how dull your blades are and how sharp you want to make them. If they are very dull, you will want to start with the coarse or medium side of the sharpener. If they just need a small amount of sharpening, use the fine side. If you've never sharpened electric trimmers before, you may want to visually observe and feel the sharpness of the blades with your fingers before you start to sharpen it. It may be hard to tell if the blades are sharp enough if you don't feel them just before you apply them to the sharpening surface.
May 02, 2010 | Andis T-Outliner Hair Trimmer
My B & D electric hedge trimmer blades are frozen
spray liberally with wd40, let side and hour spray rag with wd40 and clean blades and look for any bent teeth in blade that maybe binding them as u clean use pliers and screwdriver to move if any found, it is likely that wither sap dried or rust formed and is creating too much friction for blades to move wd40 will help free up blades
Jul 09, 2009 | Black & Decker Black Decker 16" Hedge...
Reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Jan 25, 2009 | Ryobi 18V Hedge Trimmer
Health & Beauty Logo
49 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
