Question about Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
I have a ge upright freezer storm knocked the recepticle out or tripped the breaker I reset it after 1 week of working with it it started working fine than the freezer started defrosting and the temperature alarm went off, any ideals
  • 50 Answers
Probably the thermostat has packed up
Posted on Sep 06, 2010
Freezer trips breaker
Try turning the temp control to off. Plug the freezer in for an hour and then turn the temp control down to start the cooling.
Dec 30, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire upright freezer ice forming in bottom and leaking not freezing ice cream
This does not sound good because the breakers tripping may indicate a compressor windings short. Have someone do the test below,
Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Feb 07, 2013 | Frigidaire 20 cu. ft. / 566 liter Upright...
If it is tripping the breaker when the unit is in defrost this is will not be the capacitor. You could have a heater or defrost thermostat issue. Please contact a professional for a full diagnosis.
Jul 30, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We have the Delfield XL 6000 freezer. We have been having problems with the breaker keep fliping off and causing to loose food. We have had Delfield technicians to come out on several occasion and they...
Ok ,
Does it trip all the time now,or only after running a while.?
If it trips right when you reset breaker with machine OFF, have the wiring checked for a dead short to ground up to the thermostat.
If it trips after running ,as it starts or intermittently there's a dead short to ground that could be any where.
You can simulate what is going on by doing this check.
Unplug machine.
Using an ohm meter,set to ohms, place a test lead on the ground prong(round one) .Place the other test lead to one of the remaining prongs.If there is any reading youv'e got a short. Try the other prong as well
However, if you get no reading there still could be an intermittent short .
Another thing to check. It might not be the machine at all.
Sometimes,if your wall recepticle is worn or old it can heat up causing circuit breaker trip.
Make sure there are no extention cords involved.
If you're on a 15 amp circuit ,you might want to upgrade to 20
Good hunting
Aug 18, 2011 | Delfield Freezers
I have a 20 cf upright GE freezer that isn't
it may be froze up, and require a defrosting. use a portable fan to speed up this process , also make sure the fan in the freezer compartment is working, with a little work and a zoom spout oiler, or some light motor oil, the motor can be sparked back to life.. freeze ups are common with the high humidity we are having these days.. jay the pool pump motor repair guy longwood Florida
Aug 02, 2011 | GE Freezers
My freezer is not working. The light on the front is not on. Does this mean that either the switch with light is not working or the power cord is not working?
check first the convenience outlet or the main breaker reset if trip off or replace together the cord test it the continuity using ohmmeter also check the over load protector of the compressor replace if busted. also check the bulb if busted replace it.
Feb 23, 2011 | GE 7 cu. ft. Chest Freezer FCM7DR
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Circuit breaker tripped and freezer off 24 hours. When reset, 8 shows on front of freezer and no sound from motor. Light doesn't work inside.
dear sir /madam
if your freezer,s electrical safety switch is tripped of it,s an electrical problem it can be possible your compressor getting extra load and there is some electrical trouble please contact to your freezer maintenance personnel for further action.
hope answer the question
thank you
please vote!
Aug 16, 2010 | Frigidaire 12 cu. ft. / 340 liter Upright...
No power while plugged
It probably has a circuit breaker located on the bottom of the fridge, behind the front filter. Also try looking inside the refridgerator side at the top. It may be red colored to indicate it is safety-related. Just push it in - but don't be surprised if it trips again.
WARNING: RESET ONLY ONCE TO AVOID A FIRE OR ELECTROCUTION SITUATION.
You may have an internal problem, in which case the freezer's circuit breaker is your best friend!
Note that the self-defrosting freezers have a timer that shuts them off periodically so they can defrost. Sometimes the timer does the defrosting in the middle of the day, giving the appearance of a failure. This could be your problem.
Oct 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Everything works fine, except when the compressor kicks in the panel breaker trips.
Most likely a short in the compressor electrical components (relay, overload,capacitor) Supco makes a 3 in 1 that you could use. If this works fine, if not "bad compressor".
May 27, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
121 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Michael Van Der...
Michael Van Der...
Are you a Danby Freezer Expert? Answer questions, earn points and help others
