How long should my Laptop battery last?
I purhcased a dell Inspiron a few days ago. The battery charges in about 2 hours, but then dies after i use it for 2 - 2.5 hours. Is this normal? The only discription on the site as to which battery is a Lithium-ion type, but it does not go into specifics on how many hours it should work.
  • thompsonl16 Mar 27, 2009
    i purchase a brand new emachine laptop and let it charge but the battery dies pretty quickly in about 90 min.
If you are running alot of programms and your screan brightness is on full your laptop battery will die fast.
try running one or two programms at a time. this will lenthen your battery time. plus dont leave it charging all the time this will ruin your battery.
Posted on Oct 09, 2009
Yep that's about right.....you can lengthen how long it will last by turning the brightness of your screen down. you can also dish out a good chunk of money and buy a battery that will last about 4 hours.
Posted on Jul 28, 2008
Hi i have an acer aspire 5735 and the battery only last at most for 2 hrs, i have also tried turning the brightness of the screen to as low as poss but that does not appear to makle a difference,
can any one suggest what i may be doing wrong,
p.s i only have one page open at a time normally as well.
thanks
Posted on Apr 24, 2010
    Genius:
  • 2,785 Answers
Yes
Posted on May 13, 2008
I bought a Dell Inspiron 1318 about 3 years ago, new. About a year ago my battery stopped taking a charge. I just decided I needed to buy another battery online from BattPros.com. I followed the...
Hi
Check this
When your shut down your computer and plug your the charger in your laptop that time Orange lite is showing on. if no showing then its problem to your laptop
Jun 05, 2011 | Dell Inspiron 1318 Laptop Computer PC...
I Have toshiba satellite ( Vista) and have been using the laptoop perfectlys ince last years with no problems. But since last few days i have observed that the battery incon reads as " PLUGGED IN , NOT...
i have the same problem with my dell inspiron 1501 i have two chargers and 2 batteries and 2 inspiron 1501's to narrow it down i switched them amongs the 2 identical laptops when i put the certain battery in either laptop it says PLUGGED IN , NOT CHARGING and i have a good battery which i switched amongs both tops and it charges to 100% so i'd have to say yes its the battery
Sep 02, 2010 | Computers & Internet
My Dell Inspiron 6000 battery light flashes four times amber then once green. It's been on for the last two days and still has not fully charged. It went from 85% to 95% charged over the last 24 hours. Any...
Yep, Id get another battery if I was you. I bet it runs down pretty fast too. sounds like one of the cells in the battery is dying.
Now if this is a new generic battery off ebay or an Amazon type store then those typically dont last very long so it could still be a dead cell. To get a good as OEM battery you usually either need to spend the bucks or rebuild it yourself. I dont suggest trying to do that unless you are really into electronics and soldering etc.
Mar 09, 2010 | Dell Inspiron 6000 Notebook
My laptop is dell inspiron 1501 but no work keybord and battery charging but supply line(AC adaptor) is ok.
Hello there. The Inspiron 1510 was released almost 5 years ago. If your system is more than 2 years old, then perhaps you will have to replace the battery. Battery for the most part, will only last 1 to 2 years. As for the battery, try connecting an external USB keyboard. If its working, then you need to replace the laptop's keyboard. Hope this will help.
Mel
Feb 13, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1545 power adapter not charging machine
if it is under warranty please take it to the service center if you try doing anything by yourself that may damage the warranty and it may pinch your pocket,
Aug 08, 2009 | Dell Computers & Internet
Battery Not Identified.
hello
I suggest you a few steps to solve your problem.
  • remove the charger and press the power button till all residue power is radiated.
  • then connect the charger and charge the battery fully and try booting the system.
  • if this don't work check the output of your charger and see if it is working fine.
  • if it is working fine then remove the battery and connect the charger and try starting the system.
  • if it works then there are two things possible.
  1. battery gone.
  2. IC responsible for charging is gone.
i hope you can figure out the problem through this.
Thank you
Aug 07, 2009 | Dell Inspiron 1525 Laptop
Dell Inspiron E1505 won't recognize new battery
It won't charge or work correctly if it's not the correct one and of the right voltage etc.I don't know how the battery even went in if it's not the Dell specified battery.If it went in and looked to fit maybe the battery itself is bad but its hard to say.
Aug 04, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 6400 Battery
your miracle,most laptop batteries have a life span of 4 years tops,but that if you take care of it,but most dont realize over charging kills the cells in your battery,and if you have it plugged up make sure you go into power settings and put it on ac/dc power settings.and if you have it away from home without power,put it on best battery settings,and let the power die all the way down before recharging,that will give it a full charge lasting longer.but as for your battery it might be time for a new one
Apr 14, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 1501 battery won't recharge fully.
Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
Mar 15, 2009 | Dell Computers & Internet
Help!!
proably bad motherboard
Jan 25, 2008 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
1,342 people viewed this question
David Payne
David Payne
