Question about TruTech PLV1615T 15 in. LCD Television
Bad picture Picture worked when new for a few hours, sent to $25.00 with tv for repair to the manufacture, worked fine four a few hours and has same problem. Cannot adjust picture, has the appearance of a negative picture with some color, fussy.        Thanks Jim
  • Jules21 May 19, 2008
    Yes, the same thing here. The TV worked for about 30 minutes, we sent $25.00, and the TV to Alco Electronics (guess their name is Venture now) got the TV back and it worked for about another 30minutes. The picture is like thermal imaging and you can't make out what's going on in the program. I've put in another call (they are on holiday today 5/19) and don't know what to expect. I sure wish that Target would honor exchanging this TV but since we only use it at camp sites with full hook ups we weren't aware that it didn't work until after their exchange period had passed. I wouldn't suggest buying electronics from Target. Just beware.
    Champion:
  • 367 Answers
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on May 20, 2008
Toshiba 32C100U popping sound no picture
Might be worth the effort to open it and have a look for loose plugs or a ribbon cable somewhere--if do look for any plugs that are held down with tape near where they plug in.
Jun 14, 2012 | Toshiba 32C100U 32 in. TV
I cant get a picture on my tv. DM Tech LM37xty
Either bad main logic board or bad lcd panel. If bad panel, it's not worth repair. Can find main board at Encompas Parts.
Nov 16, 2011 | Televison & Video
DU-37LZ30 LG TV Sent it in to the shop to get repairs, changed out caps. Work for a few days, then started up again with the clicking when turn on. No picture, sent back to shop did not do it again...
send to certified LG service center.
ask to replace power board and inverter board.
if price is >50% of new tv. then just get a newer bigger one.
Jun 12, 2011 | Televison & Video
My HyVision LCD TV Picture disappears after a few seconds
It seems that the "backlight" has gone bad. "Backlight" is the device that allows to see the picture in an LCD TV, when they are about to go bad the symptom that you describe is very usual. It depends on the tv manufacturers and model to expect how long the "backlight" is going to last in a tv.You can shop around for a replacement part and try to do it yourself or take it to an especialized technician. Good luck..
Jan 03, 2010 | MegaVision Hyvision Megavision 191 19"...
Picture goes diagonal
U know how to solders?Ur convergence it dead,must replaced.Tries these websites for convergence kit.Tv repair World.com,Tv repair kits.
Nov 13, 2009 | Toshiba 50HM66 52" Television
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
TV has sound but no picture...
This is a pitcure tube problem, either you buy another picture tube and change it on your TV or if this is under warranty better to send it back to the manufacturer and have this one repair.
Jul 14, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
SV470XVT Vizio picture freezes
Hello, This seems more like an interface problem then a board issue. Which interface are you using Component Video, HDMI or , RF(F Connector)? If you are using the RF (F Connector) there might be a problem in the tuner including the RF and IF sections on the circuit board. If you are using HDMI there might be a problem in the HDMI Integrated Circuit If you are using componente video the there might be a problem in the video circuits connected to the RCA jacks of the Component video input. If I were you I would have the take the TV back to the shop and have these items checked out, because board swapping is not the proper thing to do. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Vizio VO47L 47 in. LCD TV
Picture goes bad (fuzzy&scrolls&lines) on Hitachi projection tv
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 14, 2017 | Hitachi 50UX57B 50" Rear Projection...
Sound is fine, but no picture
could be a bad solder connection or maybe the CRT socket has come off slightly. I lean more to a bad solder connection at the flyback area screen G2
Dec 14, 2006 | RCA F36650 36" TV
TruTech PLV1615T 15 in. LCD Television Logo
49 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
