Question about Sanyo PLC XU50 Multimedia Projector
Sanyo XU50 not coming on after lamp replacement
I replaced the bulb in my Sanyo XU50 projector and cleaned the filters. Now when I switch it on using the mains power, the power light goes red, when I press the power button the light goes to green and the fan starts up, then the amber lamp replacement light comes on and the power light then flashes red. If anyone knows how to fix this it would be gratefully appreciated.
  • 1 more comment
  • Anonymous Feb 05, 2009
    I have the same problem. Pls. advise solution
  • mrizzle Feb 27, 2009
    I have almost the same problem but it is with a sony vplcs21
    i have replaced the lamp and the unit worked once after that it would not power back on all the way, it starts to power up it gets in posistion but no image and it eventually powers off after about 3min. help!!!!!!
  • Anonymous Mar 26, 2014
    replaced lamp and cleaned filters, now the projector will not power up.
I replaced the bulb reset the timer and viewed it for a little while 30hr or so., shut it down and now it won't turn back on. I plug it in, the light go from green to red and the fan starts up.
Posted on Oct 04, 2008
  • 563 Answers
Hi oatesy13
You will have to reset the lamp timer to resolve the problem.
Consult ypour user's manual on how to do this.
Should do the trick , If you do however need any further assistance , please send me a request and I'll respond to it.
Posted on May 13, 2008
Sanyo PLC XU50 Projector turns on and works for a few seconds then the fan comes on at a higher speed and the projector goes to stand by. Any ideas?
The cooling channel is likely clogged by lint and dust. We usually suggest annual cleaning and maintenance to avoid these kinds of issues. It is also possible that the fans have failed. Feel free to contact me at david@digitronelectronics.com if you would like to hav e a technician take a look. Projector Repair Bulb Replacement
Jan 20, 2014 | Office Equipment & Supplies
PLV-Z2000 Projector Your question about PLV-Z2000
what about the Projector Condition leds: POWER, WARNING and LAMP REPLACE? How are they lit? For good measure you should also clean the air filter (the projector might not be getting enough air to cool the lamp)
Jan 09, 2012 | Sanyo PLV-Z2000 Projector
Sanyo pcl-xu50 flashing red power light when i turn on my projector the light goes green it powers up for about 20 seconds then the power light changes to a red flashing one for about 10 seconds then back...
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Office Equipment & Supplies
Hello Is there anyone who can help. My problem
It's allways best to check your User Manual for any LED signs, go to your providers website, input your device, and download if any manuals for it. there you will find what the trouble is.
i presume that the bulb on your projector has gone bad. hope this helps!
Aug 18, 2017 | Sanyo PLC XU50 Multimedia Projector
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
My Sanyo PLC XE31 wouldn't switch on, bulb replacemetn lamp was lit. Changed bulb and now it switches on, green light shows, fans run, and then after approx 30 seconds the red light flashes and it switches...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 24, 2011 | Sanyo FOR PLC-XE31
How do i reset the timer
go to the menu, find lamp settings then select, lamp counter resit. confirm.
Oct 22, 2009 | Sanyo PLC XU50 Multimedia Projector
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
Flashing red Power light, but unit won't start
I had a similar problem, but with no lcd lights showing and the technician diagnosed as being caused by a faulty Ballast which he said caused the bulb to fail. He didn't test the bulb but his experience indicates that even if the bulb was not blown it would have been stressed and it would only be a short time before it fails completely.
When these fail there is no real reason for it it seems but it has been suggested that a probable cause could be not cleaning the filter, at least every six months. The result of a dirty filter would be overheating and this could be the cause of the failure. Perhaps you will have to check the ballast for problems
Jul 28, 2008 | Sanyo PLC-XU58 Multimedia Projector
Sanyo PLC XU50 Multimedia Projector Logo
643 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
