Question about Kenwood Excelon DNX-9140 Car GPS Receiver
My dnx9140 wont turn on all i get is a blinking red light at the bottom lefthand corner. It was working fine when i went to clean out my backseat everything just shut off could it be the radio fuse?
3 Suggested Answers
  • 63 Answers
SOURCE: i hit a bump and the radio shut off and the screen
One of your power wires is loose. There should be two of them. One is constantly connected to +12 volts and one is connected to the accessory on your ignition system. If your clock resets after you hit the bump, it is your constant power that is loose. If your clock stays with the correct time, your accessory wire is loose.
Posted on Feb 25, 2010
franktilt
  • 403 Answers
SOURCE: i cant get it to turn on the red light blinks but thats it
check the ground. it is most likely disconnecting also check the fuse between your battery and the amp and the actual amp fuse.
Posted on Jun 03, 2010
2002 dodge ram alarm system
Try leaving the key in on for 10-15 minutes. If the blinking theft light stops blinking and goes out, it has reset. Turn key to off, and then try to start it.
Feb 18, 2014 | Cars & Trucks
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
My Maytag Dishwasher wont run
check to see if your float is work properly. the float is the little dome that sits in the front lefthand corner at the bottom. lift it up a couple on time gently and make sure there is no debris such as a spoon preventing the float bob from going all the way down.
Apr 17, 2012 | Maytag MDB6759AW Dishwasher
The red light in the bottom left corner keeps blinking and it wont turn on. Yet when i unplug the tv and plug it back in the blue light comes on but then turns into red light blinking again and it wont...
Ur tv power supply board have dead componnents call capacitors.These capacitors are leaking gas,and it bulges up on it top or puff up on it top.These capacitors parts are dead,they must be replaced.U know basic electronic's and soldering?Take ur tv aparts,the board where the power cord plug into it.That ur power supply board,searches all around for these dead gas leakage capacitors,replaced them.Ur tv power LED light will be stable and the tv power will work again.Or tries websites like Shopjimmy.com,ebay.com to buy a whole reburbish power supply board for the replacement.
May 24, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
50" phillips plasma wont turn on
I'm having the same problem and am about to try this solution. I truly believe this is going to work. I hope this helps!
http://www.youtube.com/watch?v=OsJSzYVUWVA&feature=related
Dec 28, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Have a panasonic 47" HDL projection tv..under 5 years old model # pt-47wx53g, chassis Ap 825,manufactured August 2003 Purchased Oct. 2003. Have cable service..TV works fine until 2 weeks ago. Screen...
3 blinks means the convergence circuits are shutting the set down. Usually the convergence ICs will take care of the problem, but I would recommend getting the service manual from the following link, as they will provide you free support to help you diagnose why it wont start as usually the convergence ICs wont prevent a set from powering up, unless another component in the convergence circuit has failed.
http://servicemanuals.vstore.ca/
Mar 24, 2008 | Televison & Video
LG 32LC2D Power light Blinks but set will not power on.
change your adc(analog to digital converter) board will help out
Jan 30, 2008 | LG 32LC2D Television
Kenwood Excelon DNX-9140 Car GPS Receiver Logo
181 people viewed this question
Top Kenwood GPS Experts
Michael Galve
Michael Galve
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
