Question about Amana DLE330RAW Electric Dryer
Replaced fuse on heating element lasted only 30 days and installed another one this one only lasted 3 days what could be the problem
  • 50 Answers
It could be that the element is packing up.
Posted on Sep 06, 2010
Dryer overheating on timed dry/no heat settings
Replace the thermostat. A very inexpensive thermocouple that is not sensing the heat anymore and caused the element to overheat. In the UK the part will cost less than five pounds!
If the element had touched the ground, your safety earth leakage breaker in the fuse box would have tripped.
Mar 20, 2014 | Frigidaire Electric Dryer
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
Apr 28, 2013 | Water Heaters
Bottom element not heating
DEPENDING ON USE WITHIN THAT YEAR IT MIGHT NEED REPLACING AS IT COULD HAVE BURNT OUT.
Oct 13, 2009 | Ovens
Heating element has stopped working just 2 days
use a multimeter to check the continuity of the heating elements. if there is an open, replacing it will solve the problem.
Aug 04, 2009 | Dryers
No heat
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Apr 21, 2009 | Kenmore 62802 Electric Dryer
Hotpoint BD52 oven very slow to heat up
You may have one leg of power that is out. First turn off the breakers, then back on. Check it to see if it is better. Then check the wiring from the receptacle, to the plug, to the back of the oven. Look inside the back of it and see if you see any fuses. They could be blown as well. If you are getting some heat (red) then it is an indication of a wiring or fuse problem. Now, one last thought here, if you turn it to high heat does it heat up faster? This one lead it to be in the control switch. Let me know how you do.
Feb 13, 2009 | Hotpoint Ovens
Bottom baking element remains on
From a consumer repair stand-point; I would inspect, test for continuity and or replace your oven bake heating element.
How to Replace an Oven Bake Heat Element: While ensuring power off when servicing; Remove (2) mounting screws and slowly back-out the element about 3" or so. Then, disconnect and remove wires located on each side of heat element; re-install new element.
Should problems still exist, contact me.
- C
Jan 27, 2009 | GE 30" Self-Cleaning Freestanding Electric...
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Amana DLE330RAW Electric Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
