Question about HP DeskJet 3740 InkJet Printer
I control panel under pinter it says paper yam
Please help I am trying to print from windows vista all the drivers are right and everything is set up right when I try to print it doesnt want to and when I go to control panel to look why it gives, it gives a error "paper jam" but there are no paper jams please reply, thanks for your support guys
  • 975 Answers
In this case , what iLL do is to "REBOOT" , UNISTALL EVERYTHING that has to do with the HP printer , I mean everything ,after deleting all driver of printer , go to START , click SEARCH , and write " hp deskjet 3740" click search , if something shows , delete it , then install the drivers again ,
this is in case you havent found the solution for this particular issue , hope this helps , AJ
Posted on May 13, 2008
Printer offline wont print cant get back online
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
Duplex still has problems printing double sided.
Hi, Please find the work around steps to resolve duplex printing issue in Windows Vista. Please the send the *.gpd files to the cu via mail before doing the steps. Duplexer Printing for Windows Vista Troubleshooting steps 1.start-all programs- accessories ? cmd -right click-run as administrator 2.Stop the Spooler service - Type net stop spooler 3.Change current directory Type cd windows\system32\spool\drivers\w32x86\3 4.Backup the old gpd files - Type copy hp*.gpd *.bak 5.sent the zipped file to customers email address through astro and then download the file to customers desktop 6.extracted the files from the zipped folder and then pasted those files to windows\system32\spool\drivers\w32x86\3 7.Remove old BUD file Type - del HP*.bud file 8.Restart to spooler service - Type net start spooler 9.checked under printing preferences if the both sided printing is selected as automatic and then tried printing a two page document 10.checked whether its printing or not. 11.) Start-Control Panel- Printer & Faxes- Right Click On the printer -Properties-Device settings-Disable the manual Duplex printing-Click on Installed Two sided printing-click on apply & ok. 12) Then Go to Right Click on the Printer-Printing preferences-Paper quality-Select Two Sided Printing from the top drop down list where its showing What do you want to do? 13) From Print on both sides-Select Automatically from the drop down list. 14) Try to print on both side check whether its working or not.
Sep 18, 2009 | HP PSC 1510 All-In-One InkJet Printer
I have a canon pixma ip4200. When printing it draws the paper in but then stops. The heads print as if the paper were there but the printer doesn't draw the paper through. please help...!
Use Fit-to-Page Printing (Windows) The Fit-to-Page function automatically resizes the image to fit the size of the page being used. Letter size image data, for example, will automatically be printed on 4" x 6" size paper. Paper sizes larger than the printer can handle will be available on the Page Setup of the printer driver but will not print unless the Fit-to-Page function is enabled. Note: The Fit-to-Page Printing function is not available when Borderless Printing is selected.
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the Page Setup tab.
  3. Specify the 'Fit-to-Page Printing' settings.
(1) Select Fit-to-Page Printing.
(2) Select the size of original document created in application program. Paper sizes larger than the printer can handle will be available.
(3) Select the actual size of print media.
Click 'OK'.
I hope it helps!!!
Dec 02, 2008 | Office Equipment & Supplies
Print is not centered on paper
There are two possible culprits for this problem.
1. The wrong driver is being used for your printer.
2. The paper thinks it is printing to different sized paper than it actually is.
To solve the first case:
Verify that the correct driver is being used. Go to the Control Panel (Start, Settings, Control Panel) and open up the Printers and Faxes component by double-clicking on it.
Right-click on your printer and go to Properties.
A new window will pop-up. Go to the Advanced tab and verify next to where it says 'Driver' that it lists your model of printer.
To solve the second case:
Exactly as you did above, under the Advanced tab, click on the 'Printing Defaults' button.
Then click on the Paper/Quality tab on the new window.
Under the Paper/Quality tab click on the 'Advanced' button.
A new window will pop-up. Where it says Paper/output, expand it (click the plus) to list Paper size. Change Paper size to match the size of the paper you are printing (Letter is the default 8.5" x 11").
Nov 22, 2008 | HP Photosmart C3180 All-In-One InkJet...
My all in one printer 922
what operating system are you using? if you have windows vista then go to the dell site, download the patch under the windows vista drivers. run the patch, it will remove all traces of the software then download the latest vista driver form the dell site and install it. if that doesnt work then try this.
1. Download the latest Vista driver.
2. Disconnect the PC from the network/Internet
3. Delete the printer
4. Disconnect the printer from the PC
5. Uninstall the software from Device Manager (you have to choose
view, show hidden devices). Right click on the printer and choose
6. Uninstall the software from the program group or the control panel.
7. Reboot
8. Delete everything in C:\windows\system32\spool\drivers\w32x86\
9. Install the Vista Driver reconnecting the printer when the driver
install calls for it.
Good luck
Nov 17, 2008 | Dell 922 All-In-One InkJet Printer
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
Print queue stops document and will not resume
Clearing the Print Queue in Windows:
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
Please don't forget to rate the solution.
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Check printing
Open HP Solution Center, Click Settings ---> Print Settings.
Click Features tab, select the Paper Type as Plain Paper.
Select appropriate Paper Size under Size. Click Ok.
Now Print Cheques from Quicken.
If the issue still persists, Navigate to Printers folder, right click on the printer icon and click Properties. click Advanced tab, enable Print directly to printer. Click Apply.
This should now Print the Cheques.
If the issue still persists, install alternate drivers in Vista.
Here are the steps:
Click Windows logo ---> Control Panel ---> Printers.
1) Click Add Printer
2) Select local printer
3) Choose Port as LPT1
4) Choose HP and then select HP Deskjet 6500
After the driver is installed, perform below steps:
1) Right click on HP Deskjet 6500 printer icon in Printers folder
2) Click on Properties
3) Click on Ports tab
4) Choose USB001
5) Click Apply and click Ok
Now try to print.
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printer keeps saying change paper size
Go to Control Panel - Printers and on MF3310 right click and choose Default settings. I had to change page size from Letter to A4 and output size from Match page size to A4 as well. Finally, after 4 hours of investigations it worked.
Jan 30, 2007 | Canon MF3110 All-In-One Laser Printer
HP DeskJet 3740 InkJet Printer Logo
Ben Johnson
