Question about Royal ezVue 7
Royal Extreme 7 will not sync properly. It gets to Deleteing records and locks up. Both the software and the PDA is then locked into the sync mode. I have installed newer drivers as instructed by Tech support. (MwNTXP.inf & rylm100.sys Files) These files are listed under PDO Desktop>Drivers>WinNY2KXP. I am using Windows XP Media Center Edition. I have version 1.5 of the PDO Desktop program. Is there a later version that works. Frank Mattox
2 Suggested Answers
SOURCE: I have a Royal ezVue
Frank Mattox
Posted on Sep 06, 2010
I have a Royal ezVue 7 PDA and I can't get the sync software to work. The computer reads and installs the software from the CD, and the desktop software appears to work, but to sync the desktop to the PDA...
Frank Mattox
Sep 01, 2010 | Royal ezVue 7
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
I cant sync my pda pls help,
get the proper sync software. Check the usb cable and conect
Aug 15, 2009 | Palm TX Handheld
Want to download from pda to PC
Use Microsoft Active Sync if your PDA is compatible to Microsoft software via a USB cable. If not Microsoft, consult your PDA manufacturer for how to sync.
Apr 19, 2009 | Computers & Internet
PDA clock and appointments change at sync by one hour
I am running vista and havent had this problem, as a matter of fact if you have vista you no longer need activesync. Vista comes with a built in software application to sync you PDA, there si no logical solution i can think of that would cause this problem other than your computer may need to be updated, and also vista will update all the drivers for the dell x30 as well, just make sure it is able to do all updates, not just microsoft ones.
hope this works for you!
Mar 11, 2009 | Dell Axim X30 Pocket PC
HP IPAQ 111 Handheld PDA
If you want to "wipe" the PDA heres how:
-you may need two people to do this,
-hold all three buttons together: START, OK, VOICE
-keep holding these buttons and push reset for 3 seconds
-let go the reset
-then let go the 3 buttons
-the Ipaq will go into CLEAN BOOT mode and start over again
Let me know if these worked.
Feb 11, 2008 | LG KU990 Viewty
I'm lost already!
Sounds like your PDA is not communicating with the desktop software properly. (is it a refurbished unit?). I would recommend you un-install the desktop software completely, then do a hard reset on the unit. This should start you from scratch. Then, re-install the software and re-boot the TX and configure it, and try a brand new sync. If this doesn't help, you might have to return it. But first, try it with the desktop software on a DIFFERENT computer.
Good luck.
Nov 13, 2007 | Palm TX Handheld
Deleteing recorded stuff
I had my YP-T7J since 2005 and it's only when I started to use Windows Vista that this problem occured. Since I just Synced the player with my media library, I just reformated the player just to delete the recorded audio and then just synced back the music files. Kind of a tedious work but it's worth it. There is no longer support for 2005 Samsung media players.
Nov 04, 2007 | Samsung Yepp YP-T7JZ MP3 Player
Help I killed it???
Contact DELL for instructions, they should be able to help you.
I think they have some kind of resolution for that in the service-agreement you got when you bought the PDA.
It's really difficult to do anything like flashing or update the software on the PDA since its a DELL.
Oct 11, 2007 | Dell Axim X51v Pocket PC
Royal ezVue 7 Logo
79 people viewed this question
Top Royal Computers & Internet Experts
Jaime Hernandez
Phillip Whisenant
Phillip Whisenant
Jim Keysor
Are you a Royal Computer and Internet Expert? Answer questions, earn points and help others
