Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
The Hitachi 51F500 set suffered a picture and sound loss this morning accompanied by a burning smell. The screen picture fluctuated before the system died. The power light is on, and tv signals are received by another tv.
  • Hitachi Master
  • 11,800 Answers
Burning smell usually signals that a part burned. This is a major malfunction, the power source of the tv was literally fried. Replacing it will be quite expensive - around $250 - and definitely a job for a pro - who know what else was damaged in there, the tv must be tested by someone who knows this very well.
Posted on Sep 06, 2010
No sound
You may have switched the speakers off--look for that in setup part of on screen menu.
Apr 18, 2012 | Hitachi 51F500 51" Rear Projection...
No sound and black screen on my Hitachi 57F500 57 in. Rear Projection HDTV-Ready Television. But if you hook up a video game console you hear sound.
Hi
Have the unit serviced you have no high voltage going to the picture tubes. The most common failure part to suspect is the Deflection Board.
Mar 10, 2011 | Hitachi 51F500 51" Rear Projection...
The color went green all of a sudden on my 51F500, and the autofocus won't fix it.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 14, 2010 | Hitachi 51F500 51" Rear Projection...
How do i set up surround sound on a hitachi big screen tv model 51f510
On your jack panel in the rear of the set look for the Audio Output Jacks. They will be Red and White. Just run the cables from there to your Aux Audio Input of your surround sound receiver.
Oct 23, 2009 | Hitachi 51F500 51" Rear Projection...
Have power but not picture or sound
check the power regulator at power supply and filter cap
Jul 02, 2009 | Hitachi 51F500 51" Rear Projection...
Hitachi 51G500A and the screen when blank
Hi I am vortash I have just looked at the service manual for this set and it actually does not use a bulb as it is not an Lcd or DLP projection TV . It actually employs three CRT based tubes that produce the picture with automatic focus and convergence systems . If you do not have the manual for this set you can download it from http://www.safemanuals.com free of charge It says that if you have sound and no picture turn the set off and unplug it for 3o seconds then replace plug and turn on from switch on set not from the wall plug switch .. as this may reset the tv and cure the problem .. hope this helps regrads Vortash
Jun 08, 2009 | Hitachi 51F500 51" Rear Projection...
Loss of oil/oil pressure and fluctuating oil pressure
could be that the screen in the oil pan where the oil is taken up is clogged. not certain--maybe oil change?
Mar 02, 2009 | 2005 GMC Sierra
I have a double picture on my 6 year old Hitachi Projection tv.
Required info are available in service manual with details and schematics.
You can buy service manual from Manual Zone for your Hitachi 51F500 TV.
Thank you.
Dec 11, 2008 | Hitachi 51F500 51" Rear Projection...
"burn in"
The burn in can't be fixed cheaply.You would have to replace the burnt crt guns.The screen can be removed for cleaning.behind the speaker grill are several screws right below the screen.Remove them and slide the whole screen assembly upward.
Mar 05, 2008 | Hitachi 51F500 51" Rear Projection...
Picture on track
The problem is an assembly called the "Flex Converter". This is not available from Hitachi, even though the set is relatively new. The converter must be removed from the set and sent out to Hitachi for repair.
Jan 19, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
108 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
