Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge freezer hotpoint ffa70 - The freezer overheat light came on and the freezer stopped working, followed by the fridge not working about 4 days later. Now it just doesnt work at all!
  • Hotpoint Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 06, 2010
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70
This will work in most all cases of this type. You need a piece of copper wire, 14 guage, 12 to 16 inches. You can shortin it as you need to Turnoff the power to the fridge. Rap one end of the wire around the evaprorator heater and feed the othe end down the drain tube. This wire will heat up when the heater comes on and will supply heat down into the drain tube hopefully preventing the drain from freezing.
Nov 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
HOTPOINT FFA70 FRIDGE FREEZER
I had this problem and it was fixed relatively easily. Get everything out of your fridge freezer and switch it off overnight to allow it to defrost.
In the bottom freezer compartment there is a panel behind the draws which you can remove but you will need a special tool from a DIY shop. Its like an allen key, but with a star shaped end.
When I got the panel off I found that the filament was covered thick with ice even though it had been off for hours. No wonder it wasn't working properly. I melted this with a hairdryer. You want to take your time with this as you could easily damage the freezer if you try chipping the ice out.
Freezer works perfectly now and is very quiet.
Jun 02, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Chilling Fault
You are probably frozen up which causes the fan to freeze up. Thoroughly defrost the unit...if necessary, stop it for a day or more until all the ice melts. Restart. Cut down on 'window shopping', storing uncovered liquids. Check the door gaskets, clean if necessary or replace.
Jan 03, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
198 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
