When the machine is started it fills with water,it then trys to turn and the fuse blows.
  • 50 Answers
Check underneath if you can turn the motor easily by hand. It is probably the bearing/s that is/are ceasing up which causes the motor to strain and overheat and blow the fuse.
Posted on Sep 06, 2010
My machine fills with water and before the drum starts to rotate, it blows the fuse.
If your talking about tripping the breaker its designed to trip under load. Yes if something is keeping the drum from turning that put a load on the breaker and trips it..It will keep tripping until there's no over load on the drum...I'm guessing your talking about a washing machine... You can take the belt off the motor and if the motor is good it will turn on but not spin the drum...Then you know the motor is good and something is preventing the drum from turning. And if the motor is bad you can smell a burnt smell if you get close enough to the motor..Hope this helps
Jul 01, 2017 | Washing Machines
Wi121 fills ok then trys to start drum is not turning dial gos round and flashs
check the belt if it's ok check the heater if its ok check the time of the water filling it should not exeed 3 to 5 minutes
Feb 10, 2014 | Indesit W 123 Front Load Washer
Cant get washer to pump out the water
Water pump Is shot can be fixed parts labor not cheap better to get new washer then it comes warranty sorry
Feb 21, 2013 | Washing Machines
Machine fills but wont do anything else
try the Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or your motor coupling could have broken!
Jan 09, 2010 | Washing Machines
When i turn my waher on it starts agitating without any water in it
You can a defective water level switch or a clogged air line going to the switch.
Open the control panel to access the water level switch. Remove the hose from the water level switch and blow through it. Blow very hard until it is clear. Replace the hose on the switch. Set the machine to spin and turn it on. Let it spin for 1 minute. Turn it off then back to fill. If it does not work OK then, replace the water level switch.
Aug 26, 2009 | GE WDSR2080D Top Load Washer
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
Keeps filling with water when turned on
A lot of wahing machines use a bunch of micro-switches to turn the various solenoids on and off. If your washer has that type of switch, it could be sticking, subsequently sending an "on" signal to the fill solenoid.
Apr 19, 2009 | Washing Machines
When we turn on our front load washing machine it trys to drain. it does not start filling with water it acts like it might be stuck on the drain cycle
Seems it detects water from previous run. Is common phenomenon on bad drain hookups or faulty vacuumswitch. Rarely, the timer is damaged.
Apr 09, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
