Question about HP f2105 21" LCD Monitor
HP F2105 2" LCD Monitor
Hi there...
I received a new computer last Christmas and was thrilled with the large monitor. However, three months after the warranty expired my monitor started going "black". At first, I was able to get it to come back on by pressing the buttons and hitting the escape key. This lasted for about two weeks, and steadily became more frequent. Then finally the monitor just went black and I was never able to get it to come on again, but, the power button was always on. I tried connecting an old monitor to the computer and alas, it worked fine. I'd like to know if it is possible to repair my monitor or should I just trash it? Please respond and let me know if the repair can be done by me or is it better to have it repaired in a shop?
Sincerely,
Denise
IM I ABLE TO FIX MY MONITOR MY SELF
Posted on Jul 24, 2008
    Genius:
  • 2,785 Answers
It will be better you give it to shop
Posted on May 13, 2008
Scepter 32". Received this for Christmas 2012. It's worked beautifully up until about a month ago. When you turn it on the blue light comes on but nothing happens. You can't turn it back off without...
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
It's not unusual for this type of electronics to only last a couple of years.
May 03, 2014 | Televison & Video
I have an HP L2208w monitor which has been ok for the last two years. Suddenly, it started to display patches of different colours. Also vertical and horizontal colours appear across some pf these patches....
hi steven_katas
Im thinking that this maybe a LCD panel problem (dead pixels) already. some LCD panels last for 2-3 years depending on usage. even if you haven't dropped it or anything the LCD panel's pixels ten to give way slowly or die down since these pixels are like bulbs. here's what you can do. Try connecting a different cable from your monitor to your computer if the issue is still the same, try connecting a different computer or maybe a laptop to your monitor just to eliminate the probability that it can be a cable or a video card problem.
If you have already connected a new computer say a laptop and it is still the same it might already be a hardware problem with your monitor and might need you to bring it to the service center for repair.
Hope this helps please let me know
janc30
Feb 13, 2011 | HP L2208W Monitor
Iiyama HM903DT - Stopped switching on - constant orange standby
The way I solved it…
I received from iiyama a quote for repair: 400€ without VAT, 478 € with VAT, with a 3 month warranty.
So I ordered a HP LP2475W H-IPS LCD monotor from HP, for 656 € VAT & delivery incl. And a 3 year ON SITE warranty. It is superb, and after calibration it largely outperforms what I had before for my photographic use.
Hope this will help…
Jan 17, 2009 | iiyama Vision Master Pro 454 19" CRT...
Dead Monitor
I do not what type of inverter you have is it true wave? some inverters are cheep as they are not a true waves and they do effect the life of the Tv/Computers, etc. Tv still covered take it back and do not tell them that you connected it to inverter
Jul 25, 2008 | HP Compaq WF1907 Monitor
Hp monitor 18" LCD color d5063
Turn the monitor upside down and turn on the lights in the room.
Then you will see a location for a power cord, remember three wires/prongs. Good luck.
Jun 21, 2008 | HP Pavilion F1703 17" LCD Monitor
Can't see screen to install diver for HP Compaq WF 1907
My friend just purchase this monitor yesterday. When she plugged it in to the back of the tower she received the same prompt u have mentioned. I was able to repair it because she simply did not realize that I had installed a new graphics card into her pc a few months ago. When u do this, you have to hook your monitor into the area where the new graphics card was installed. You can not plug your monitor into the same onboard card that u have previously plugged your monitor into.
Let me know, if by chance, u did install a new graphics card.
Hope this was helpful :)
Jan 30, 2008 | HP Compaq WF1907 Monitor
Display problem
A fuzzy display is not likely to by caused by programs on your computer. Is this an LCD flat panel monitor or a regular CRT monitor?? If it's a CRT, the problem could be with the high-voltage power supply, which would need to be diagnosed by an experienced computer1.gif or electronics technician.
Check to see if there is a small focus knob on the back. If so try turning it back and forth three or four times to "clean" it....then adjust for correct focus.
Symptoms like this can also be caused by accumulated dust inside the monitor.
Jan 18, 2008 | Gateway FPD2275W LCD Monitor
HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
Oct 29, 2007 | HP Pavilion F1703 17" LCD Monitor
Acer AL1715s
Hi, Maybe it is a stuck pixel try this link perhaps this will give ya some insight ... But it sounds as if ya monitor is going flakey :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 20, 2007 | Acer AL1715s (Silver) 17" LCD Monitor
HP f2105 21" LCD Monitor Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
