Question about NorStar M7310 Corded Phone
Can't make outgoing calls
Everytime I press any button on the phone, it beeps and wants me to select a line. What can I do to fix this? I have tried unplugging the phone. I can except incoming calls but can't dial out. Help!
  • M7310 May 22, 2008
    Yeah, I do press a line. Thanks turns out my phone did not work so I had to get a new one!
    your sooo funny! I am 100% Latina...I had blonde highlights once but let my hair grow back to its natural color ~dark brown. Gosh you got the entire office cracking up!!!
  • 3 Answers
You have to press a Line to call out. Line 1 or Line 2 or Line 3
Posted on May 22, 2008
  • Brittstephen May 22, 2008
    Oh haha... I thought you were like a real blonde. :P
    Cheers!
P3015 beep
Here are some possible reasons why your printer is beeping:
1. Your printer is connected to a UPS (Uninterruptible Power Supply). When the printer goes through the printing cycle it uses a massive amount of electricity. During those few seconds of power usage, the UPS will beep indicating that it will not be able to sustain that power output for any period of time.
How to fix: Move your printer to another outlet and don't connect it to a UPS
2. You have an MFP (multi-function printer) that is attempting to fax again and again. When sending a fax, it's typical that the printer makes noises (dialing, connecting, etc). One of these noises is a fax response beep.
How to fix: Check your printers menu and turn off/down the fax volume
3. Some printers with an LCD menu and keypad make noise when keys are pressed or the printer encounters an alarm of some type. This can become annoying when typing keys for a phone number or by changing a menu setting.
How to fix: Check the menu settings for the printer and turn off/down the sound that's occuring. As an example, the HP LaserJet MFP series printers have the following sounds.
  • The alarm sound that the printer makes when it requires attention, such as when the all-in-one
    door is open.
  • The beeps that are emitted when you press the all-in-one control-panel buttons.
  • The phone line sounds for outgoing faxes.
  • The ring volume for incoming faxes.
As an example, change alarm volume by following these steps (using a 305X series printer)
1. Press Menu
2. Use the < or the > button to select System setup, and then press the green checkmark button
3. Use the < or the > button to select Volume settings, and then press green checkmark button
4. Press the green checkmark button to select Alarm volume
5. Use the < or the > button to select Off, Soft, Medium, or Loud
6. Press the green checkmark button to save your selection
Mar 20, 2014 | Office Equipment & Supplies
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
    http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
    All releases of Partner
    Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
    This feature is called "Auto line select"
    To program Auto line select:
    From extension 10 or 11:
    Press feature 00
    LEFT INTERCOM
    LEFT INTERCOM
    RIGHT INTERCOM
    Enter the extension number of the extension you need changed.
    press ** (start, star)
    Then the order you want the lines to get picked up
    Then ** (star, star) when done
    When finished, press feature 00 to get out of programming.
    So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
    Easy as pie.
    Aug 20, 2011 | Avaya 700340193 Corded Phone
    When i pickup the phone i want the intercom to be my first option not a line out?
    One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
    1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
    2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
    Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
    I need help with my binatone 1810
    go to call setting on your phone then go to barred outgoing call to unbarred the out going calls
    May 29, 2010 | Lands Phones
    KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
    3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
    4. Press AUTO DIAL / STORE to save your changes.
    5. Press PROGRAM to exit program mode and you are done.
    Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
    How do you change the message on my GE 28821FE2-A cordless phone?
    1. Make sure the answering system is ON. 2 . Press and hold the announce button until the speaker announces “RECORD ANNOUNCEMENT AFTER TONE“. 3 . Begin speaking after you hear the beep. 4 . Release the button when you finish your announcement. NOTE: If you choose not to record an outgoing announcement, a default announcement plays instead. To return to the default announcement after you have recorded your own outgoing announcement, press the announce button and release it when you hear the beep. Or, press the delete button while the announcement is reviewing. Sample Outgoing Announcement Hi, this is (use your name here), I can’t answer the phone right now, so please leave your name, number and a brief message after the tone, and I’ll get back to you. Thanks. NOTE: The maximum recording time for the outgoing announcement is 2 minutes. Reviewing and Choosing the Announcement Press and release the announce button to review and select this one as your outgoing announcement. NOTE: Press the PLAY/STOP button at any time to stop playing the announcemet
    Mar 25, 2009 | General Electric 28821FE2 Phone
    Avaya 18D unable to make outgoing calls
    Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
    At one of those ext's press the feature key and "00"
    Next press the left hand intercom twice
    The display should say system programming
    Press the right hand intercom once. The display should say Centralized Programming.
    Enter in the extension number that you want to program.
    enter **
    press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
    enter ** when finished with line selection
    Press feature "00" to logout
    Hope that helps
    Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
    KX-T7600 series outgoing calls
    1. Press "PROG" (Program)
    2. Press "1" and "9" (19)
    3. Press "ENTER"
    4. Select "Idle Line"
    5. Press "ENTER"
    6. Press "EXIT"
    Jan 30, 2009 | Panasonic KX-T7630 Corded Phone
    Samsung E900
    Sound settings Use this menu to customise various sound settings.
    Incoming call
    Use this menu to select a volume level and alert type
    for incoming calls.
    Alert type: specify how you are to be informed of
    incoming calls.
    Ring tone: select a ringtone for the call ringer.
    Volume: select a ringer volume.
    Keypad tone
    Use this menu to select the tone that the phone
    sounds when you press a key.
    Message tone
    Use this menu to set up the ringtone for incoming
    messages.
    Menu functions
    Tone: select one of several message tones.
    Alert type: specify how you are informed when a
    message comes in.
    Repetition: specify how often the phone informs
    you of a new message.
    Power-on/off tone
    Use this menu to select the melody that the phone
    sounds when it is switched on or off.
    Slide tone
    sounds when you open or close the phone.
    Silent mode
    Use this menu to set how the phone acts to alert you
    to a specific event in Silent mode.
    Extra tones
    Use this menu to customise additional tones for the
    phone.
    Minute minder: set the phone to beep every
    minute during an outgoing call to keep you
    informed of the length of your call.
    Connection tone: set the phone to beep when an
    outgoing call is connected to the system.
    Alerts on call: set the phone to beep when you
    receive a new message or when the time for an
    alarm comes during a call.
    Indicative tone: set the phone to beep when a
    pop-up window displays.
    Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
    NorStar M7310 Corded Phone Logo
    284 people viewed this question
    Top NorStar Lands Phones Experts
    Oloyede Monsuru
    Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
