Hi, i'm not able to setup internet connection eventhough i have installed the ethernet driver. i have no idea whether its outdated or corrupted. my comp details are below: OS: Windows XP service pack 2 motherboard : ASUS MS 6526 ver:2 when i check in the device manager, there's a ? symbol next to the ethernet driver... kindly suggest the reqd driver.. pls help me
    Sergeant:
  • 286 Answers
Try this
http://www.howtodrivers.com/model548794.html
Posted on Sep 06, 2010
Check whether the main internet connection is attached properly to the router.by connecting the direct ethernet input cable to your laptop and testing whether internet is accessible to you. If it works then you can plug that cable to the master input of the router. It may be needed to setup the ethernet settigns again by logging into the router as admin user and validating connection.
Hope this helps.
Feb 16, 2014 | Computers & Internet
Tip
How to install device drivers using driver files without a setup
Obtaining drivers is a very important aspect in the everyday use of a PC since outdated drivers need to be updated. Drivers can be downloaded from many different sources on the internet and through many third party software programs. Whatever the source, there are a number of times that people download drivers and they realize that what they have obtained are just the raw driver files without any setup. A lot of people get stranded in such cases. The following, is a very simple way of installing these driver files:
Whether under Windows XP, Windows Vista or even Windows 7, do this:
1. Click on the start button and right-click 'My Computer' or 'Computer'.
2. Select manage and wait for the resulting window (if asked whether to continue, continue).
3. Select 'Device Manager' from the left panel.
4. Now, depending on the device you want to install the driver for, or update its driver, right-click the device (you may have to click on the plus sign to reveal hidden devices). select the first option (update driver software) from the drop-down options.
5. In the case of Windows Vista and Windows 7, select browse my computer for driver software and then browse for the folder that contains the files.
6. In the case of Windows XP, select the last option which avoids the internet and click next and select manually locate files and next. Now add the location of the folder that contains the driver files.
7. Click next and Windows will automatically install the driver files for your device.
8. Restart your PC and you are done.
This procedure is not necessary when a setup file is available unless the setup file is corrupted but the driver files are available.
Hope this was helpful and all the best.
on Feb 19, 2010 | Computers & Internet
Driver windows7
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver or you could download one
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
http://download.cnet.com/2000-20_4.html
on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.htmlRather doing a driver hunt which can take hours
http://download.cnet.com/SlimDrivers-Free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Aug 30, 2013 | NetGear GA511 - 10/100/100 Gigabit PCMCIA...
My wii won't connect to my cisco e10000 and I already checked the security settings !!
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps i just read something on the setup of a cisco
Use the Cisco connect software for the initial set up of your new E series router. While running the software for the first time it will ask you to connect the modem to the router. But will not ask you to connect the computer to the router. However it will be better if you connect the computer to the router with an Ethernet cable. Otherwise it will not find the router and you will get the error "we did not find your router". Run the program and at the end it will connect you to the Internet. You don
Jun 26, 2011 | Computers & Internet
I can't connect internet although i have a driver for it
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection
during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses
if you already have the internet
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
hope this helps
May 22, 2011 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
I ALWAYS GET AN ERROR UPON USING THE ROUTER TO MY SMARTBRO BROADBAND INTERNET.
because you have not stated what the error code is unable to point you
if you are referring to your internet connection
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
also you might check
check the leads from the modem/router whether usb ethernet make sure they are not bad/faulty and have secure connection
hope this helps
Apr 28, 2011 | Computers & Internet
I cant log on to internet
check the password make sure its exactly how you provided to your ISP internet service provider make sure the Caps lock is on/off which ever applies to your ISP contract
check your computers settings ie: firewall also he might have a default internet setting
check the leads from the modem/router whether usb,ethernet make sure they are not bad/faulty and have secure connections and try different ports
click start control panel administrive tools computer management device manager scroll to network adapters + to expand any yellow ! ? or a red x will mean that the driver is corrupt and needs to be updated
hope this helps
don
Feb 26, 2011 | Dell Computers & Internet
Ethernet not work
Check in the Device manager to see if all the devices are enable and working.
The one with a yellow ? against that device requires a driver installation.
Is the LAN device OK?
How do you intend to setup your LAN, is it for Internet access or a home network?
I need more information on your problem, together with error messages.
Jun 24, 2009 | HP Pavilion dv6000z Notebook
How do I use DriverDetective on a computer not connected to the Internet?
you can install driver detective whether you are on the internet or not, by downloading it with an internet accessed computer saving it then copying it onto a disk or usb stick. Put it on your computer and install it, it will still check your computer for outdated drivers and drivers that need updating.. Make a note of the drivers that are needed, and use an internet based computer to download the drivers that you need and then copy them to a disk and install them on your computer
I hope this helps
Dec 30, 2008 | Computers & Internet
Ethernet Network controller
use driver updating software ie driver magician. it scans ur outdated drivers and automatically downloads drivers that r compatible for your computer.............
Dec 25, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
David Payne
David Payne
