Question about GE Hotpoint® HTS18GBS Top Freezer Refrigerator
My GE Hotpoint HTS18GBS is a top freezer unit and although it is turn almost off everything on the bottm shelf and in the drawers are freezing.
  • 88 Answers
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
Posted on Dec 06, 2008
kachbibi1
  • 979 Answers
SOURCE: Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Posted on Jan 14, 2009
Maytag317
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
Posted on May 30, 2009
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Posted on Jan 04, 2010
jmgldsmth
  • 1869 Answers
SOURCE: TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Posted on Jul 02, 2010
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Drip
Might find the reezer is totally frozen, i know it sounds wrong but when they freeze over the water trough & hole become iced over, you may find the defrost element has failed or the drain hole is blocked.
Nov 20, 2013 | Hotpoint-Ariston HTS18GBS (18.2 cu. ft.)...
Ref practically new, intermittent leak onto floor at left rear ref is model HSM25GFTCSA side by side
check drip pan, if it full of water and there is no heater on this model you need to upgrade it with heater under drip pan.
but check if it's not cracked and drain line goes to it and not on the side...
www.appliancesrepairla.com
Jun 26, 2010 | GE Hotpoint® HTS18GBS Top Freezer...
GE side by side # PSCS 5RGX CFSS freezer shelf fall out
I also have this problem with the same GE Profile series. The shelf sits above the "quick freeze" drawer. It's very annoying and I am looking for a way to fix it.
May 09, 2010 | General Electric Profile PSCS5RGXSS...
Bottom of fridge not cooling the top part working but vegs getting hot
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 25, 2010 | GE Hotpoint® HTS18GBS Top Freezer...
I have a Ge side by side model #GSS25TSR. It is 4 years old. the problem started 4 weeks ago. Things are freezing on the refrigerator side in the vegetable drawer and on the shelf above the meat drawer. I...
you've already discovered your problem. its not blowing. if the freezer fan motor is not blowing air through unit, the cold air falls to the bottom of both sides, and warm air at top of both sides as well. On that model, the fan itself may be bad, or it may be the main control board behind the unit. Without properly testing and inspection, I cant be certain if its one or the other or quite possibly both, And I was trained directly from GE about this.
www.FixMyFridge.net
Mar 08, 2010 | Refrigerators
What type of water suppl kit i need for the icemaker
I would say any ice maker line kit should work, they have a line tap and vinyl tubing that runs to your water supply solinoid valve on the back of your frig.
Jul 17, 2009 | GE Hotpoint® HTS18GBS Top Freezer...
Top half not freezing
If this is not a frost free unit , it probably has a freon leak. This is usually not worth fixing in a deep freeze. If it is a frost free unit the fan could be bad. This is an easy repair.
Mar 26, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Hotpoint FFA70
Remove the plastic venting box which feeds cold air over the top of the freezer drawers,There are 4 hexagon headed self tapping screws,two at top.and two bottom.Now defrost all ice off rear of freezer and back of vent box.Now replace and door will shut with draws in.Make sure no ice left round fan housing.
Jan 21, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
GE Hotpoint® HTS18GBS Top Freezer Refrigerator Logo
53 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
