Question about Cycling
The Lifecycle 9500HR does not come on--where is the battery?
I have the same issue. Can someone tell me where the battery is located? Is it in the control panel or in the base? Are replacements easy to find?
Posted on Oct 29, 2010
2 Suggested Answers
  • 1788 Answers
SOURCE: hello my lifecycle 9500hr doesn't work
Clean your battery terminals with rubbing alcohol then if it still doesn't work buy new a new battery. It may be running low.
Posted on Jan 12, 2011
Very noisy and clangs a lot , can I do anything to fix the loud noises?
I haven't seen that exact model myself, but i work on a variety of things for people and have had customers with the same complaint. my usual remedy is apply some 3-in-1 oil or even wd-40 lubricant to the parks that squeak and clank as long as no electronics are nearby to get covered, if so just take precautions not to spray your logic boards, powersupply, etc. and if and when possible, i like to use small pieces of foam stuffed into certain cavities in the plastic as long as they wont get caught in any moving parts or impede the electronics. keep in mind this wont make it completely 'silent' but it will reduce the noise factor slightly, and the lubrication may very well make the bike itself perform more smoothly.
May 09, 2016 | Life Fitness Lifecycle 9500HR Upright...
Screen wont work no display present
Most likely a dead battery,you could also check and make sure that that the sensor for the flywheel is in tact
You'll have to open up the battery assembly compartment on the user lower left side and replace your old batteries.
The LifeCycle GX power requirements are
• Battery: 2 D-Cell batteries
• Approximate Battery life: 800hrs
If this does not solve your issue or you need further assistance please do not hesitate to contact our Technical Support Team online or by phone 888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
Mar 30, 2014 | Life Fitness Lifecycle GX Indoor Cycle
My lifecysle 9500hr the start button does not light up
I recomend that you read your instruction manual,and check the section troubleshooting. If you do not have go to download to the next web page: www.fitness.manualsonline.com or www.iconservice.com for FREE.
God bless you
Aug 31, 2012 | Life Fitness Club Series Lifecycle...
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
Feb 02, 2011 | Life Fitness Exercise & Fitness
How to replace lifecycle 9500hr battery
The battery located at the front bottom of the bike.
Remove TORX screws from the right side and bottom cover (as if riding)
Move the cover aside to locate the battery
Remove two slot screws holding the battery
Replace with original,or alarm type battery (use plastic ties to secure)
[URL=http://s1059.photobucket.com/user/2750709/media/Mobile%20Uploads/952BFE63-B54A-417D-9B5E-F7C2706326D7.jpg.html]http://i1059.photobucket.com/albums/t436/2750709/Mobile%20Uploads/952BFE63-B54A-417D-9B5E-F7C2706326D7.jpg[/IMG][/URL]
Aug 18, 2010 | Cycling
How to dismantle Lifecycle cross trainer to move it
Hi Angie
I believe the only piece what is the mono column , but you'll need to take off the foot pedal assembly so go to this website and scroll down to the crosstrianer and click on the pdf or pdfs you need to disassemble your unit
http://www.gympart.com/index.asp?fn=/troubleshooter_bank&st=viewall
Mar 31, 2010 | Exercise & Fitness
I have a lifecycle model 9500HR, will not turn on.
Some of these units have the main battery ( 6v @ 2.5AH ) inside the bike frame and a 9v in the backside of the upper console
Feb 18, 2010 | Exercise & Fitness
I was told that my lifecycle 9500hr wasnt turning on because of the alternator. I replaced that and the display still wont turn on...any ideas of how to fix this????
You were probably steered wrong. I would expect the battery is the problem.
Use a voltmeter to check voltages.
If the battery is fully down, the alternator MAY have to have the field "flashed" to start generating.
In an automobile the current throu the alternator "idiot light" DOES THIS AUTOMATICALLY.but for your lifecycle I don't know how they do that unless the alternator uses permanent magnets.
Oct 23, 2009 | Veritas Data Lifecycle Manager Win V5.0...
Cycling Logo
894 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
