Question about LG WM-2277HW Front Load Washer
Specification of lg washer dryer model wd14338adk
2 Suggested Answers
  • 410 Answers
SOURCE: my LG washing machine WD14338ADK,after 2mins the LE sign comes up
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Posted on Nov 29, 2009
Do I have to take apart the whole machine to fix the drain pump on my LG WM3455HW washer/dryer combo? I can't seem to find any instructions on this model.
Lucky You. The newer models of LG Combo units WM34xx have the filter on the right hand side and the pump can be changed through the bottom panel.
Nov 17, 2015 | LG Washing Machines
I started the test cycle to make sure it works properly and in the middle of the test a code of D80 appears and a little smoke witch is not good. Does anyone know what this code means?
Digital control washers and dryers usually have a list of common trouble codes listed in the owners manual under, "trouble codes". Unfortunately, mostly simple codes are listed. My guess would be to check the thermister, & thermal protection fuse but you can get model specific advice in the trouble shooting section at repairclinic.com. Good luck. Try this link: http://www.repairclinic.com/RepairHelp/Appliance-Repair-Help-Lawn-Mower-Repair-Help-Small-Engine-Repair-Help
Sep 04, 2015 | Dryers
Why my wd1248 lg wont go on
Can you be a little bit more specific?
May 17, 2014 | LG Washing Machines
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Our LG WM2233HW Tromm when not in use slowly fills up with water. For example if we do not use it for 24 hours there may be as much as 2 inches of water sitting in there.
The water inlet valve has failed. They tend to get debris inside and not seat properly. You will need to replace the water inlet valve. They are usually not to expensive and easy to replace. Here is a link that should help Water inlet valve replacement You can also get diagrams and illustrations of your specific model at the same site.
Oct 28, 2010 | LG WM2233H Front Load Stacked Washer /...
How do I find model number and serial number on LG washer and dryer?
front load washer upper part inside door frame
top load upper right side back
your looking for a metal plate.. it will have the serial number and the model number.
Sep 18, 2010 | LG Washing Machines
My LG washing machine WD14338ADK,after 2mins the LE sign comes up
advice on fixya.
Nov 29, 2009 | LG WM-2277HW Front Load Washer
Lp conversion for LG dryer
After removing the three screws which pass through the L bracket into the back of the dryer:
Stand in front of the dryer and (using the palms of your hands) give the top a sharp push back on the dryer top at the left and right side of the top. The top should slide back 1 to 2 inches. Now lift the top off.
If you post again with further questions, make sure to post under the model number you have. (you posted using a combo washer / dryer, and stated you are converting to LP, which combo units are not gas.)
Apr 18, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Scratched top. Need part number?
assuming the very top cover on both units are scratched??? i have part numbers for you , but thinikin your gonna need to call cust service to order the parts, local part houses probably dont stock them(lg parts anyway).. washer part number( AGU30781501 $80US) dryer part number ( AGU30071202 $70 US)
May 10, 2008 | LG WM2487H Front Load Washer
Lg washer dryer
The DHE error is dryer heat error. It's a problem with the heating element or thermister. You can find the service manual herehttp://www.appliancefactoryparts.com/content/pdfs/129017-8.pdf
Nov 11, 2007 | Washing Machines
LG WM-2277HW Front Load Washer Logo
24 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
