I have 2 Hunter State Street 27763 fans with light fixtures that has 4 - 40W light bulbs. I wanted to change the light bulbs from incadescent 40W to "energy efficient" light bulbs 13W. One of the fan does not seem to accept the "energy efficient" light bulbs. I have tried many wattage from 10W to 23W mixed or all the same and I either get blinking, humming and when using CFL bulbs that fixture is causing interference to a radio (for example) in another room when the light is turned on. Why is that happening and how can I rectify this. I would like to use the more efficient light bulbs since the fixture is used for many hours per day. The fan was installed by a qualified electrician so I expect he must have known how to install it.
4 Suggested Answers
jayhawke
  • 338 Answers
SOURCE: We installed a new ceiling
DON"T USE TILL YOU FIX- the connections inside fixture are getting hot and expanding- OPEN SHORT_FIRE HAZARD- that is why going out after an hour and then works after a few minutes of cooling- take down and check you connections
Posted on May 18, 2011
  • 4736 Answers
SOURCE: I have a Hunter ceiling
Bill, Hunter makes many different light kits that will fit just about all of their fans. You can find them at home centers like Lowe's and Home Depot. Also, I believe that Harbor Breeze Light Kits are interchangeable with the Hunter Light kits. You'll find those there, too.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 13, 2011
  • 51548 Answers
SOURCE: Can I use a 23W CFL bulb in place of a 13W, if the desk lamp says to use a 60W max bulb?
OF COURSE less than 60 watts is it not . and they are a lot cooler
Posted on May 08, 2015
How to fix ceiling fan light
Make sure the light wire is connected to the receiver & bottom of fan.You should set the light to the on position when using the remote and leave it that way.
Sep 10, 2015 | Hunter 52" Ceiling Fan With Light And...
Looking for light fixture for hunter ceiling fan model # 25434
I can't find that fan anywhere in my old catalogs. If you have a center plug in the switchcup, you can put almost any light kit on it. If you have two screws on bottom switchcup, you need a hunter light kit.
Aug 13, 2015 | Hunter Dryers
The ceiling light on my hunter will notcome on using the remote
The receiver may not be functioning, the bulbs can be burned out or the wire going to the lights can be disconnected.
Oct 21, 2014 | Hunter Sontera 52" Ceiling Fan with...
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
RECENTLY THE REMOTE AND THE WALL SWITCH WILL NOT OPERATE EITHER THE FAN OR THE LIGHT IN OUR HUNDER FAN. THE REMOTE HAS MODEL UC7848T ON THE BACK. I CANNOT FIND ANY NUMBERS ON THE BODY OF THE FAN. THE...
Hi Does the light fixture have a globe under the fan? What does the light fixture look like? Most of the light fixtures have small screw surrounding the globe that simply unscrew and the globe drops down. All fans are different and I will have to know what this one looks like. In the mean time I will look at some hunter fans on line and see what I find.
Jul 25, 2011 | Hunter 27187 Remote Control
We purchased a hunter grand visita and when we turn the light on a the breaker box or the switch plate there is a delayed reaction before the light comes on whats going on?
Here is what hunter technical support says about this.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Mar 01, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
