Question about Belkin Wireless Play Max Router (F7D4301)
I just got verizon DSL and I can't get my Belkin Play Max router (F7D4301) to connect to the internet through the wired port or wireless.
  • shue31 Sep 06, 2010
    That didn't work. What should I do next?
  • shue31 Sep 07, 2010
    Here is the information you are looking for:
    IP Address: 192.168.1.27
    Subnet Mask: 255.255.255.0
    Default Gateway: 192.168.1.1
    DHCP Server: 192.168.1.1
    Lease Obtained: 9/7/2010 6:56:32 AM
    Lease Expires: 9/8/2010 6:56:32 AM
    DNS Server: 192.168.1.1
  • 3,083 Answers
First thought is that the router could be bad, however, there are many possibilities as to why it's not working.
Here's their setup advice (which you've probably done correctly):
I just got verizon DSL and I can't get my Belkin - c26-b003cjtnls-7.jpg Fast, Easy Three-step Setup
An easy three-step setup will get you up and running in minutes. Simply plug the Play Max into your modem, plug the router into the wall, and insert the included startup CD into your computer for quick, painless on-screen setup. To set up your network, you will need a computer with a Windows XP (32), Windows Vista (32/64), or Mac OS X operating system; an installed network interface card and TCP/IP networking protocol; Internet Explorer, Firefox, or Safari; and minimum 64 MB RAM. You will also need a minimum 1.8GHz processor and 512 MB RAM. In addition, you should allow for 100 MB of disk space per 1000 songs.
This blog explains a problem that might help you:
http://www.amazon.com/Belkin-Wireless-Play-Router-F7D4301/dp/B003CJTNLS
Here's CNET's reviews of Belkin, and it's not pretty:
http://reviews.cnet.com/routers/belkin-play-max-wireless/4505-3319_7-34057930.html
Anyway, it says to connect the router then install the CD. On some devices, this doesn't work, you have to install the CD, then connect the device. Not sure if that's your problem, but if you reinstall the Belkin CD, and then go through the process again, you might have luck. That fixed one setup problem for me awhile back.
Anyway, good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
    President:
  • 1,932 Answers
I hope you connected the router as in below diagramI just got verizon DSL and I can't get my Belkin - 7bc0f8b.jpg
1.Connect your Router’s Ethernet cable to your modem’s Ethernet port (on the back of your modem).This port might be labeled differently on your particular modem.
2.Plug the Router’s power supply into a wall outlet.
3.Put the CD into your computer.If the CD doesn’t open automatically, please browse to your CD drive and double-click on the Belkin Setup CD icon.
4.Click the Setup icon on the CD menu.
After a brief installation, the setup software will ask you for the network name and password from the network information card that is attached to your Router.Store the card under the base of your Router for future reference.
A progress screen will appear while additional software is installed. This may take a few minutes to complete.Once finished, a “Success” message will appear indicating that you are connected to the Internet via your new Belkin Router.
During setup you may be asked for additional information.
You may need to enter a username and password provided by your ISP.This username and password is likely to be found on materials that came from your ISP when you signed up for service.If necessary, you may need to contact your ISP to retrieve your username and password.
If you have a static IP address, you may need to enter additional information also provided by your ISP.
If still problem persists please add a comment
Thank You
  • Belkin Master
  • 6,487 Answers
You can follow these steps in manually configuring your router to work with Verizon.
1. Connect computer to any of the numbered ports on your router.
2. Connect modem to the WAN port or INTERNET port of the router.
3.Open a web browser like Internet Explorer or Firefox. Type this number on the address 92.168.2.1
4.You should see a box prompting you for your password. Enter your password now. By default your password is blank. Click the Log In button to log in to your router.
5.Under Internet WAN , go to Connection type and set it to PPPOE and input your Verizon email username and password then save the settings
6.once done with that power off the modem , router and computer for 1 minute then power them on and check if its working now.
Posted on Sep 06, 2010
  • Mark Gil
    Mark Gil Sep 07, 2010
    If that didn't work I need you to provide me the IP address of your computer when connected directly to your modem , to do that open command prompt then type IPCONFIG.
  • Mark Gil
    Thank you for the update, let me ask you can you access your belkin router setup page to manually setup the router ?
F7d4301
pull the power cord out for 10 seconds and reinsert it
Oct 12, 2017 | Belkin Wireless Play Max Router (F7D4301)
I can connect to the internet with my router, however periodically it will lose conection. This happens over and over again. Usually around 5-6 times during the lenghth of an average movie. I have tried...
While it's true interference could be causing the issue, there are several other possibilities.
More than likely it's not your router that's losing connection, but your actual internet connection itself. If you're using a cable or DSL service for you internet connection they may be temporarily dropping the connection. It's common in large communities, apartment complexes, etc for connections to "blink" in response to increased bandwidth loads. It's also possible that if your connection is DSL based that your telephone line is connected to a bad circuit.
I would start by watching your Cable or DSL modem and see if you notice the Internet light change status while your watching a movie (when it drops connection). If you do you, should be able to call your provider to come out for a service call.
May 03, 2011 | Belkin Wireless Play Max Router (F7D4301)
I am trying to set up belkin n600 but my internet connection is a usb from verizon how to do i connect?
Hi
Though Belkin play router has a USB port on it, it would not accept the input via that port there by you can not connected the USB connection from Verizon to the router. You need to switch from USB connection to Ethernet connection on the Verizon modem contacting verizon.
Dec 27, 2010 | Belkin Play N600 Wireless Dual Band Router...
I can establish a link to the Net wirelessly and on the LAN, but for some reason I cannot get the USB aspect working. The green light is on for the net connection and also for the USB, but the Belkin USB...
Hi you need to be sure is the default settings of your router Belkin is USB ENABLE .
  1. for that go to setup page Belkin .
  2. open a browser explore and erase the address bar
  3. type 192.168.2.1 and setup page will be open
  4. be sure USB is Enable is not just change the status of Disable for Enable
let me know is that still not working and ask me for a remote your PC
Oct 03, 2010 | Belkin Wireless Play Max Router (F7D4301)
The wifi connection to this belkin play max is not stable, sometimes get connected, sometimes not. i connected the external hard drive to the usb port, at first i can see the drive using belkin router...
OK let me disable something in your router
QOS
Supported Products - Play Wireless Router (F7D4302), Play Max Wireless Router (F7D4301)
Using QoS rules on your Belkin Router helps provide both bandwidth and priority to network traffic so it can pass without its performance being affected. It allows users to classify traffic of applications and provides them with differentiated services (Diffserv).
Setup Steps
  1. Click on the green Belkin Router Manager icon (right-click for Windows) to open the menu.
  2. On the Belkin Router Manager menu, scroll up to Router Settings and highlight.
  3. Click to open the Belkin Router Setup page on your Web browser.
You must log in with a password to make changes to your Router's settings. If you have not yet set a custom up a password, leave this field blank and click the "Submit" button.
  1. From the QoS Profiles page, you can easily set up QoS rules.
  2. Click the "Apply Changes" button to save your settings.
Also disable WPS and Firewall in router.
let me know .
please don't forget to rate techbelkin
Aug 18, 2010 | Belkin Wireless Play Max Router (F7D4301)
I cannot connect to the internet from my desktop
please check the status of the light of the router
  1. Red no connection
  2. amber only connection PC and Router
  3. green connected
  • If your ISP is DSL use a PPOE or dynamic connection type
  • If your connection is Cable just clone the mac addres in your adderess
Jun 27, 2010 | Belkin Wireless Play Max Router (F7D4301)
How do i connect my verizon dsl westell 6100 to my belkin g rtr?
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
Dec 28, 2009 | Belkin Wireless G Plus MIMO (F5D9010)
Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Dec 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin Wireless Play Max Router (F7D4301) Logo
555 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
