Question about Samsung YP-U3 MP3 Player
U3 mp3 player
I bought and i instaled the drivers and all that but when i connect the usb it keeps showing me disconnected and i tried everything already....can u please help me out with this?
  • 1 more comment
  • Schiopu May 20, 2008
    I bought a Samsung YP-U3 . It had the installation cd and everything. It's charging but it shows disconnected...so both the samsung media studio and my pc don't recognise it...Could you help, please? Thank you
  • tetriss May 25, 2008
    i have a problem with samsung yp-u3: every time i insert it into usb it shows that player is disconnected and then keeps on charging. i've tried to reset a few times but it won't help
  • good_girl0 Dec 25, 2008
    i bought and i instaled the drivers and all that but when i connect the
I bought a Samsung YP-U3 . It had the installation cd .When plug to usb port It's charging but it shows disconnected...the samsung media studio and my pc don't recognise it, allways ask new samsung YP-U3 found. when i give the path to cd it dint get. Please help me....
Posted on Jul 07, 2008
  • dolado Jul 07, 2008
    I down load firmware but how do i the rest. where i put that 2 files.
  • 8,596 Answers
Make sure the hold/lock is not engaged -p.12 of manual
If not, upgrade the firmware:
http://www.samsung.com/us/support/download/supportDown.do?group=audiovideo&type=mp3players&subtype=flashmemory&model_nm=YP-U3JQPY&language=&cate_type=all&dType=D&mType=SW&vType=L&prd_ia_cd=03040200&disp_nm=YP-U3JQPY
Posted on Jul 06, 2008
My laptop does not recognize my SAMSUNG YP-U3
hi,
please install the proper driver for ur SAMSUNG YP-U3 and also update you windows this will solve it thank you
dont forget to vote for me
thank you
Sep 22, 2009 | Samsung YP-U3 MP3 Player
Samsung mp3 player YP U3
take your mp3 off the usb and go into the settings, you should find settings for the usb connection , ,, one of the options should be highlighted , chose the other one and try again,,,, your mp3 was set to charge only just pick the other setting and it should work. that happened to me once
Aug 17, 2009 | Samsung YP-U3 MP3 Player
U3 can't connect
Solve i have a problem that my mp3 player samsung yp-u3 zb that when i connect it to my computer it stays... (More) i have a problem that my mp3 player samsung yp-u3 zb that when i connect it to my computer it stays disconnected
Jul 21, 2009 | Samsung YP-U3 MP3 Player
Samsung YP-U3
go to my computer> properties>hardware > device manager >universal bus driver>right click on it> update driver>
then1
1.yes this time only> next 2.choose advanced option>next 3don't search i"ll update from........>next4.click on show campatible> next> next 5. now it updated then restart you computer
Then try to format your drvice sir
hope this is helpfull or if problem still please type in comments
regards
golu_fixya
Apr 26, 2009 | Samsung YP-U3 MP3 Player
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Cant connect to pc
Dec 07, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Sep 03, 2008 | Samsung YP-U3 MP3 Player
Disconnected samsung mp3 player
Gday...the most likely issue concerning the "USB Disconnected" message on the U3 is that the device has installed itself with incorrect drivers. If this is the case then following these steps should rectify your problem...
1) Plug the MP3 player into the USB port
2) Open up Device Manager (Start, Settings, Control Panel, System, Hardware, Device Manager)
3) Find Samsung UP-Y3 in the list (should be under "Other" or "Portable devices" with a ? next to it)
4) Right click on this and select Uninstall
5) Remove the player from the USB port and plug it back in
Windows should automatically detect the device and install it's own drivers. If not, and you have a driver disk, then just install the Samsung drivers. You should now be abe able to drag and drop files onto the player using Windows Explorer. Hope this solves the issue.
Cheers,
Scott
Feb 17, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 MP3 Player Logo
750 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
