Need to install liteon ps-5301-08HA 300w power supply for computer. Need manual for proper connections to motherboard.
  • BirdDog_ZA Sep 06, 2010
    Hi, The Liteon PSU is a standard Desktop power supply. What make & Model mainboard to you have? The PSU power connectors can usually only fit into the Mainboard connectors in a certain way, but give me the details and i can assist. BD
3 Suggested Answers
geo_jonas
  • 555 Answers
SOURCE: computer does not turn on
you can try your power supply if it works by jumpering its pin. try to insert copper wire in pin 11 and connect it to pin 12. and turn o your power supply. But if it won't works then used tester and test its circuit boards particularly  is capacitors, resistors and even the transformer inside the power supply. Or if you can't make it then you can call a technician either in computer or electrical to test your power supply if it still working or not. In that wy can be sure in making decision if its really your power supply got problem or not.
Thanks
Posted on Jun 26, 2009
  • 1027 Answers
SOURCE: cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Posted on Jan 31, 2010
Power keeps shuting off while installing Windows XP (remaining 20 mins) 1) ASUS M4A785TD-V EVO AM3 AMD 785G HDMI ATX AMD 2) AMD Athlon II X4 640 Propus 3.0GHz 4 x 512KB L2 Cache 3) G.SKILL 4GB (2 x 2GB)...
It sounds like some-thing is overheating, an over stressed power supply or poor ventilation could be your problem.
See your power supply is Max 300W that's peak not continuous power output. I think it will only be able to continuously output around 250W of power. Which is below specifications for your computer mainboard.
The Cooler Master Extreme Power Plus range of Power supply's are an excellent choice.
I would recommend a 460Watt with 120mm fan at least.
damnor01
Sep 19, 2010 | ASUS M4A785TD-V EVO Motherboard
Hello there, I got Asus PC-DL Deluxe UAYZ motherboard and would like to connect to ATX 300W 20 pin power supply. Do you think it works, or should i wait till i find 24pin power supply. thanks for your...
This motherboard is designed to be used as a workstation or server. This mother board will need a specific power supply designed for this board as it can use 2 Xeon CPUs. Setting this board with the incorrect power supply will cause the system to not power up or at worse result in damage to the CPU, motherboard, memory, video and other devices including possibly the power supply. I suggest obtaining the proper power supply for this motherboard
The manual for this board states that the motherboard requires a 24 pin ATX power supply that also has an 8 pin 12 volt connector. The manual from ASUS recommends no less then a 300 Watt power supply. I would professionally recommend 500 watts or more if the system will use 2 CPUs and many hard drives in a RAID array.
A suitable power supply can be found here at Newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16817163111
The manual is here at ASUS's support site at http://support.asus.com/
Feb 24, 2010 | ASUS PC-DL Deluxe (90-MSV290-G0UAY)...
Cannot locate the fuse in the liteon power supply
Jan 31, 2010 | Lite On LiteOn 150W LPX Power Supply...
Hooking up a Liteon 24X DVDrw burner
The SATA drive is to be used with a motherboard that supports SATA 1 or 2.
If you have a board that supports SATA, you should also have a power supply that supports SATA.
The 7 pin connector is for data. the other connector is for power.
Hope this has helped you.
P.S. Their are conversion kits for the power supply if yours does not support SATA but your board is something else all together.
Get back to me with the make a model number of the PC and I will check if you want.
Sep 15, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Acer aspire computer with liteon power supply PY300B00153201AA6E
power supplies are easy to replace. usually 4 screws. open the pc. remove the screws and unplug it from the motherboard. a replacement costs 40-60 dollars. plug it into the same place(s) you unplugged the original pwr supply. replace the screws. replace the cover and thats it.
Jan 08, 2009 | Lite On LiteOn 204Watt PA-4022-6B Power...
Problem motherboard no power
make sure you have the proper power rating and ATX connection, your power supply may not have enough wattage to power your board, be sure its at least 300W
hope this helps
Drumwar
Jun 26, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
From 300w psu i change it to 450w will that be ok?
Ivy My field is in home appliances. I do fix my own computers and have replaced a few power supplys. The only thing I could say to you is go back and recheck your connections. They should only fit on the bord one way. The other connections for the hard drive and cd drives and so on really dont matter. so good luck and I think if you recheck it all the computer will work.
Jul 11, 2007 | Jackson 25 in. TempStar HH Free-standing...
Computers & Internet Logo
721 people viewed this question
David Payne
David Payne
