Question about LG LP6000ER Air Conditioner
My thermostat must be stuck because the compressor is running constantly no matter what temp i set it on. is there a solution to a stuck therostat.thank you
    Master:
    Sergeant:
  • 449 Answers
Check thre relay switch at the compressor it might be stuck and needs to be replaced
Posted on Sep 09, 2010
My viking under counter refrigerator freezes all liquid
Is it a digital temp. display? Does this show a low temp? It should show +/-34 degrees. Listen if the compressor runs continuously. It should run for a while and then switch off. When you change the temp setting, as you turn it down, the compressor should stop. If it runs continuously then the likely cause is a stuck/faulty thermostat.Before replacing this, switch off and leave open until unit is at room temp. Then switch on again and monitor. If the thermostat if faulty and the compressor runs continuously you can damage it by overheating. The compressor will run for a good few hours after restart, until set temp. is reached and then switch off automatically. Good luck!
Nov 14, 2013 | Viking 24" Custom Panel Undercounter...
Car never reaches operating temperature (cold weather) thus little to no heat inside
change the thermostat, sounds like it could stuck open and wont allow the engine reach operating temp, also test the constant control relay module located to the right of the battery as your facing the front of the car, also test coolant temp switch it might be defective and producing a high voltage that would cause the fans to constantly operate no matter the temp. Hope this helps
Nov 25, 2012 | 2003 Hyundai Tiburon
LG Model: LWHD1500ER - I would like the unit's compressor to remain on constantly. The temp guage seems to be off and shuts down the compressor. Can I bypass the temp guage to leave th ecompressor...
You can but the unit will have not control over temperature, and you can cause the unit to freeze up or slug the compressor w/ liquid refrigerant causing premature compressor failure. I would recommend replacing the thermostat if it is not holding proper temperature, but if dead set on bypassing it use a volt/ohm meter after unplugging it to find the normally open contacts and wire those wires together taking into consideration that the fan must run constantly with the compressor.
Sep 23, 2011 | LG LWHD1500ER Wall/Window Air Conditioner
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
I have a Magic Chef compact refrigerator model MCBR270 that now runs constantly and freezes everything I put in it no matter what setting is used on the temperature control knob. What can I do to diagnose...
Well, this answer is 6 years late.
I have the same model MC frig - 14 years old. There is only two electrical components; the compressor and the thermostat. Since the compressor is running and freezing, the thermostat must be stuck on. You need to replace the thermostat. My thermostat is also bad. I can't find one. One of the numbers on the thermostat is LR62862. Another is PFN-110U 02D. May be time for a new frig.
Feb 06, 2011 | Maytag Refrigerators
The kegerator temp is a constant 20 degrees no matter how i set the thermostat..what should i do
sounds like the thermostat is stuck or not functioning, bump it really hard and see it you can free the contacts up, dont bend anything, just bump it
Sep 19, 2010 | Computers & Internet
High Temp light will not go off even though the freezer seems to be working. Compressor does not stop running
What makes a compressor to run constant is the thermostat. Bang on it to see if it will turn off. turn the setting to 1. if it still wont shut off replace cold control (aka thermostat)
worry about the light later hope this was helpful
Mar 29, 2010 | GE 13.7 cu. ft. / 388 liter Upright...
Freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
Nov 20, 2008 | Haier Freezers
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
LG LP6000ER Air Conditioner Logo
62 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
