Question about Boating
Efi wiring schematics 1999 Indmar 5.7 330 hsp
Is the hazard relay blue in a 1999 Lincoln navigator? If so I have already changed that I still have no lights.
images for 1999 lincoln navigator wiring
Lincoln Wiring Diagrams / Schematics - YouTube
? 1:11
https://www.youtube.com/watch?v=n5wOPtPCwpE
Nov 19, 2013 - Uploaded by Robert Nauert
Lincoln Wiring Diagrams / Schematics ... Lincoln Aviator, Continental, LS, MKS, MKT, MKX, Mark Series, Navigator, Town Car, Zephyr and MKZ.
Jan 28, 2016 | 1999 Lincoln Navigator
Where is the cooling fan control located on a 1999 jeep chrekee
cooling of the engine? or you, A/c? cooling.
guess at engine cooling....
deep in side the PCM is answer
better, its now software , there. .
the pcm on new cars, have a EFI sensor called ECT
the designers woke up one day, and said hark, why have 3 sensors
1 for fan
2 for A/c
3 for EFI.
answer, was, you don't.
the FSM is free, to see, and look at that.
why not post the symptoms so we can tell you what is wrong and not guess.?
The ECT is the main engine coolant temp sensor
if this sensor is over about 215f, they PCM closes the rad coo
i must warn you , if you dont have A/c as some dont. the engine has
a fan clutch, as fully stated in the FSM.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
free to look, posted 100s of times here. but there it is,
see engine cooling chapter.
then see the schematic for the wiring of the fan relay.
both pages tell you what you have.
if its HVAC cooling, then see HVAC
May 03, 2014 | 1999 Jeep Cherokee
Indmar engine timming
Check out the following links, these are specs and manuals:
http://www.bakesonline.com/images/MediaLibrary/IndmarIgnitionTiming.pdf
http://www.aquamarina.co.il/userfiles/file/Service/User%20Manuals/Indmar%202011%20Operator%27s%20Manual.pdf
Feb 27, 2013 | Clymer Indmar GM V-8 Inboards 1983-2003
Why does my efi fuse keeps popping 1999 chevy prizm
Pull the EFI relay, replace the fuse, and see if it blows when you turn the key on. If it does not turn the key off, reinstall the EFI relay and remove the circuit opening relay/fuel pump relay. Turn the key on. If the fuse blows than we know the problem is One of the O2 sensors, the IAC, the purge solenoid, or the ECM You can unplug the O2 sensors, iac, and purge solenoid. Replace the fuse, turn the key on, and plug them in one at a time until the fuse blows. Replace that component. If the fuse blows with those unplugged than its probaly the wiring and possibly the ECM. let me know what you find and I'll help you more if needed.
Aug 05, 2012 | 1999 Chevrolet Prizm
Electrical wiring diagram 99 flhtcui
Hi Haysrck, for a free wiring diagram please visit the website below and good luck. Harley Davidson Wiring Diagrams and Schematics
Jan 23, 2012 | Harley Davidson FLTR-FLTRI Road Glide...
1999 sc2 wiring schematics
wiring schematics can't be copied and uploaded to fixya.com in my experience, unfortunately.
The memory required apparently is not available and there are copyright issues.
I think that your best bet is to buy a paper manual like Haynes or Chilton or the Manufacturer's manual to get detailed schematics for your Saturn SC.
Aug 24, 2010 | 1999 Saturn SC
Hsp bruchless
Hi there
I have the same electronics on hsp rally monster pro. 3300kv - but 75A ESC, i upgrade it to 6000kv with 5000A lipo without any programing to the ESC . it worked fine for couple of runs but i faced wires over heating problems after that something wrong went to the ESC !!! . .
Am going back to 3300kv, but need advice of what is the higher ampers/voltage battery can i use?
Apr 10, 2010 | Electric Novatech High Speed Brushless 70A...
I need to know how many wires go to a 1989 ford econoline fuel pump with a 460 efi engine
I suggest check this wiring diagrams for code color wires...
1989 5.0L & 5.8L & 7.5L ENGINE SCHEMATICS
1989-91 CHASSIS (GASOLINE)SCHEMATICS
1989-91 CHASSIS (DIESEL) SCHEMATICS
Hope this help.
Mar 23, 2010 | 1989 Ford Econoline
Boating Logo
98 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
