Question about Compaq A3000 All-In-One InkJet Printer
Problem My Copier is asking me to Add right cart. I have just put a new black in and I don't know what to do, can you help me? Lisa
  • Anonymous Sep 05, 2008
    copy mode tell me the same thing-add right catridge. Both catridges are knew
    from stapler
  • 148paan Sep 05, 2008
    yes - when I copy letter, it tell me the same-add right catridge. both catridges are knew from stapler.
    also cannot print adobe document-printer did not recognized the font
    Genius:
  • 2,785 Answers
Dear lisa
is your cartridge is original,just check with the old cartridge is the problem arises,post your findings
Posted on May 13, 2008
Hp cp2025 remove shipping lock
I had same problem with black and blue cartridges. I did all recommendations -- return to factory setting ( no help). Shake cartridges REALLY hard ( no help); reinstall printer/ driver ( no help). What finally WORKED was SWAPPING the cartridges around ( for ex. put red in black spot, blue in yellow). I then got an error message ( b/c in wrong spot). Then I placed them back in correct spots and it WORKED !!! NO more error message that the ship lock was on !!! And this worked with generic cartirdges.
Nov 19, 2011 | HP Laserjet Cp2025n Printer
My af 220 still got toner sign on after i add new toner
Is the toner cart you put in a third party? If so mite require OEM cart only
Apr 03, 2010 | Ricoh Aficio 250 Copier
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
The add toner light stays on with a new toner cartridge
Yes, the machine will only make single copies if the toner light is on. Was the toner cart genuine Copystar? Or perhaps Kyocera cart? The machine is made by Kyocera and marketed under both name brands, however, the toner carts are different for both machines. I have seen many times that aftermarket carts will not always work properly.
Jan 06, 2009 | Copystar CS-1510 Copier
I have a canon image runner 1370 f.
Are you trying to replace the old toner or is this the first time -- new out of box? There is a pattern / order you have to follow to replace the cart. To make it easier, have the right cover open while doing this ( replacing the carts). Also make sure that you have the protective covers and tape off of the cart. Use the light colored area on the cart. to hold and DO NOT TOUCH THE DRUM !!!
Dec 30, 2008 | Canon imageRUNNER 1023N Black and White...
Noises when printing copies
Take the new cart. out and reinstall the old cart. Does the noise disappear? I would tap and shake the toner cart. BUT BE CAREFULL, the cart is ready to spill toner. On the box and in the instructions it tells you, or should, that you must shake and tap the outside of the cart. This is due to settling and the toner maybe packed. By tapping and shaking it will feel the toner. If the toner is packed it will put undue pressure on the augers inside the toner cart. and cause a grinding noise. If after tapping and shaking, reinstall the new cart. and check. If everything is ok -- great. If the noise remains contact the company your purchased the cart. from and ask for a replacement. These cart. are mass produced and mostly reused ( refurbed). Parts wear now and they do not replace the inside parts, they just repack with toner and seal.
Dec 25, 2008 | Sharp AL 1631 Copier
Problem with aficio 1035
The developer should probably be changed in it. the cartridge should be inspected as well. Was there any toner spills?
Jun 21, 2008 | Ricoh Aficio 1035 Copier
Won't print from 3ebk cartridge
i think there is problum in ur cartridge cas adoptor , clean cartridge circuit plate and put cartridge then try
Jun 05, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Compaq A3000 All-In-One InkJet Printer Logo
50 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
