Question about Garden
Looking for a manual for a Sears 919.175960 Air Compressor
  • 76 Answers
Where is the reset button on sears air compressor #15364
if your compressor has a reset button its going to be right next to where the power cord goes into the motor , most times there red but not allways , also air compressors use a demand switch as well , there usually is a manual off lever on the side of these , this will interrupt the automatic start feature of the compressor and wont allow it to run , just follow the power plug wire the little "possibly grey " box it comes too is the demand switch
Nov 22, 2016 | Air Tools & Compressors
What kind of oil to use in craftsman air compressor model no. 921.16476
According to the manual you need Use synthetic, non-detergent air compressor oil. you can get it at sears, Home Depot, Amazon.com
you can get the manual from this site
http://download.sears.com/own/spin_prod_683856201.pdf
Oct 06, 2012 | Air Tools & Compressors
I purchased a used Craftsman 2 HP 20 Gal air compressor, model # 919.176220. I'm looking for a copy of the user manual, Sears # SI-30-14-4-C. This item is no longer available from Sears.com and doesn't...
Since the exact model number manual is not available go to Sears and look at the compressors they have on the floor (or in the catalog). Find one that looks like the one you have and note the model number (these devices haven't changed much over the years). order the manual for the one that matches your machine the best.
Mar 22, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
Compressor fills air tank and when it cycle to refill tank it kicks a 20 amp dedicated circuit breaker. Sears looked at it twice and said it is OK. Changed breaker with new one because Sears said it...
try this. When compressor shuts off. TURN OFF POWER. then spin the compressor backwards or forwards until it is off the compression stroke. Turn unit back on. If it doesn't blow the breaker, then it is worth looking into the type of compressor (pump) you have. Many have a "reed valve" and that might be failing, holding the compressor itself under load when it shuts off so that on restart it is under heavy load and the motor draws too many amps to get it started hence blowing the breaker anyway hope this helps
Feb 17, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
I am trying to locate an owners manual for a sears compressor
I can help you. The motor name plate will give you the connections for the different voltage if it is a 'dual voltage' motor. Check the name plate on the motor.
May I ask why you want to change it. Contrary to popular belief, It won't make it cheaper to run.
Jul 13, 2009 | Air Tools & Compressors
Sears 5 h.p. air compressor model 919176850 convert to 110 volt
pull the cover where the wiring goes into the motor, usually there is a wiring diagram on the underside. If not, go to sears online to see if you can get the manual for it
Jun 09, 2009 | Air Tools & Compressors
Garden Logo
529 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
